Question about Pioneer DEH-1900MP CD Player
Radio problems I put a new pioneer cd player in a mazda 626.Now the fuse for the taillights and dash lights keep blowing.What did i do wrong?
Does the radio also go out?
if not, then you miss wired something as in the orange wire or your after market wireharness adaptor is incorrect.
Recommend buying a repair manual to double check proper wiring
Posted on Apr 09, 2008
Taillight fuse to 1999 Mazda protege keeps blowing out
need to inspect the bulbs and holder of the tail lights
bad earth , corrosion ,
if brake lights faulty could also be pedal activation switch
if no better
it may be the tail light switch at the dash
Oct 28, 2016 | 1999 Mazda Protege
Fuse keeps blowing to my dash guages in my 95 gmc sierra why?
have you recently installed a new radio ? I have knowen people to install radiosincorectly the dim wire behind the radio shows as a earth. however when you turn headlights on this becomes a positive. if you have wired this wire to your sterio this is whyyour dash lights & internal cab light etc keep blowing.. if your wondering why sterio still works is because its earthed through the aerial or mounting bolts.
Jan 05, 2013 | 1995 Chevrolet Silverado 2500
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
I have a honda odyssey 2001 the light of the panel are not workinkg all the rest of the lights are working i check the fuse and are ok only i did was change the radio and install a new one but did not...
I'm guessing you're talking about the dash light aound the radio. The dash lights around the radio share the same fuse with all the other lights that come on when you turn the parking light on. If the other light are working then your fuses are fine. What i think might have happen was when you took the dash cover off, the bulbs behind it might had burn out. You might want to try new bulbs.
good luck
Jan 20, 2011 | Honda Odyssey Cars & Trucks
'02 mazda 626 tail lights out
Check your fuse located underneath the drivers side steering wheel. Flip the fuse box cover lid over and you will find a diagram. Pull the taillight fuse out and replace it with the same number fuse. If your taillights still don't work then you will need to replace one of the burned out bulbs. Pull each bulb out and test it with a multimeter for continuity
Dec 20, 2010 | 2002 Mazda 626
The tail light fuse keeps blowing in my Mazda 626
if u just put in a cdplayer thats whats doin it
Mar 07, 2010 | Mazda 626 Cars & Trucks
Keep blowing fuse for rear taillights and dashboard lights
Sounds like loose wires. Had a similar problem with my 03 Durango. Kept blowing fuses when I put them in. Came to find out my trailer wiring harness had fried and was shorting out.
Apr 07, 2009 | 2001 Ford Focus
Tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Mar 04, 2009 | Pioneer DEH-P6400 CD Player
Radio Blowing Tail Light Fuse
by the way you tell me that the radio illumination is the gray wire and all of the rest you are wrong. try the correct way red is key positive,yellow is constant power,black is ground,orange is illumination,blue is remote,gray is right front positive and gray black is negative,white is left front positive and white black is negative,green is left rear positive and green black is negative,violet is Right rear positive and violet black is negative,
Nov 23, 2008 | 1993 Oldsmobile Cutlass Ciera
Electrical issues
the lights are probably wired through the radio my blazer is like that you will need a wiring diagram of the radio and the lights to figure it out
Nov 17, 2008 | 1998 Mazda 626
Pioneer DEH-1900MP CD Player Logo
87 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
