Question about Fuji FinePix A350 Digital Camera
LCD display My LCD display does not work anymore.When is on there are some colourful lines,but I can`t see nothing through.
This 1.7" LCD is made by AUO and it is most likely defective. You may try reseating the internal ribon cable of the LCD connected to the printed circuit board by opening the camera back case (5 small screws) with a tri-wing screwdriver size #000. Care must be taken as the flash light charging circuit is active and touching certain area of the board may give a big shock once you have access to the internal guts of the camera.
Posted on May 10, 2008
How to fix AOC LCD TV random vertical coloured lines, no response to controls
Sounds like a screen fault. The adhesive that attaches ribbon cables from the drive electronics to the screen has failed. Unfortnately this isn't fixable because the connection and spacing is too fine to get a 100% reliable connection. Some DIYers have used neoprene rubber tubing as wedges to hold the connections in place. That actually works. Search Youtube
Sep 07, 2014 | AOC Televison & Video
I brought 3 samsung LCD from harmon house dubai now 3 LCD in india there is one LCD is complaint (comming center line and color change) i told your service center thrissur kerala india but their asking...
The central vertical line in the display is due to the damage caused in the LCD display due to impact..probably during shifting.As result of it the colour mixing fails.
The colour could also fail due to colur IC chips failure too...due to impact or voltage fluctuations.
You will find lot of Purple,& green in the display.
Get it serviced in a authorized center.
Sep 19, 2011 | Televison & Video
ViewSonic VA2226w, horizontal light coloured lines through image regardless of resolution. They get worse when the monitor has been running for a while. Display otherwise working, powers up and down fine...
The lines appearing on the screen have nothing at all to do with the resolution. If the OSD display is correct (when the LCD is not connected to the PC), then the possible issue could be the RAM. Open the PC case and check if you have more than one RAM stick. Try using one RAM at a time and swaping RAM slots to see if the display is shown correctly. Make sure that the PC is turned off and power is disconnected before you remove/ install RAM. Most of the times lines appearing on the screen are due to faulty RAM. I suggest that you may also connect the LCD with some other PC to check if the issue is with the LCD or not.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
Jan 18, 2011 | ViewSonic VA2226W LCD Monitor
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
The lcd display is not working properly; is there a source for parts?
the lcd display on three of my moultrie i40s shows nothing anymore, is there anything that can be done to fix this?????
Nov 04, 2009 | Moultrie Cameras
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
My fone shows a black screen but i can still recieve calls
1. perhaps LCD is faulty
2. Software reload may also solve the problem if LCD is OK.
Aug 10, 2009 | Sony Ericsson W910i Cellular Phone
Display screen going whitish in colour
Change the mother boardof the cell phone
Jul 11, 2007 | Samsung SGH-X700 Cellular Phone
Fuji FinePix A350 Digital Camera Logo
46 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
