Question about Brother IntelliFAX 1820C Plain Paper Inkjet Fax
Brother Intellifax 1820c fax machine: Won't print incoming transmissions
Brother service advisors said that there was dried ink in printer head. Error 41 is what keeps coming up when you try and run a test page. Is there a way to clean the printer head without taking to an authorized service center? There is no dried ink where the ink leaves the cartridge and enters into the cartridge holder.
  • 2 more comments
  • atzamyboaat Feb 14, 2008
    Everytime I get a fax it says there is an error 41 to unplug the machine and contact Brother
  • ccaltd Mar 06, 2008
    Error 41 showing. what can you do to sort, have cleaned 5 times. Any quick fix tips
  • desz Mar 28, 2009
    I have a brother 5440 fax machine that wont print. I did replace inks at a ink replacement place, would that effect it
  • Anonymous Mar 14, 2014
    yellow ink not working, have changed cartridge several times and been through cleaning process
How do you fix the error 41 that keeps showing up
Posted on Feb 14, 2008
    Scholar:
  • 78 Answers
I wish there was a way to recover them but there not and have tried most things. The only way to fix this is to replace the printhead with a new one.
Posted on Jan 25, 2008
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
Want to change it to black and white printing only.
A manual for your fax is available here, and will show you how to set your fax to monochrome mode.
Apr 14, 2008 | Brother PPF-1820C Plain Paper Inkjet Fax
Drum error message
check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Error 41 is showing up on the screen. says to contact brother. It's a intellifax 1820c.
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Apr 21, 2009 | Brother IntelliFAX 1820C Plain Paper...
Fax machine says error 41 unplug and call brother.
unplug all the connections and reconnect everything back.also checkout for any blocked paper or any paper jam.also remove and check out the cartridges from the printer and reinsert.either its the internal circuit failure error and has to be repaired to make it proper. thanks.
Dec 15, 2008 | Brother IntelliFAX 1800C All-In-One...
I replace the ink on my fax 1860c brother
the print head is contaminated . you can tray to clean the the print head fron the menu but will use a lot of ink. the only other thing is to replace the print head. around 60.00 for the part. need to use bro.ink
Nov 23, 2008 | Brother IntelliFAX 4100 Laser Fax
Error 41 shows
Error 41 is a printhead failure. The only way to fix it to replace the printhead there unfortunately is no way to recover the printhead. If you decide to replace the printhead please do not leave the machine of for extended periods of time (causes the printhead to dry out as it can not do its cleaning cycles), use only genuine ink (I see a lot with this failure with non-genuine inks or refills) and do not cheat the ink system by running empty inks (Dries out the printhead). Just a few tips to extend the life of your printhead.
Mar 06, 2008 | Brother IntelliFAX 1820C Plain Paper...
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Brother Intelifax 1820c problem
that is a printhead error. call brother and see if its under warranty by giving them the serial number. if its not, the last i knew, the printhead w/ cartridges was about $100.00. hth, ray
May 31, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 1820C Plain Paper Inkjet Fax Logo
554 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
