Question about Hobart N50 Stand Mixer
N-50's need restoration
I have two Hobart N-50's in need of ground-up (counter-up?) restoration, and I'm having trouble obtaining a service manual. I'll soon be disassembling them, stripping the paint, etc, and getting ready to order parts. They both seem to have good motors, but the transmissions don't look great (and don't work). I've heard that Hobart is worried that home mechanics might get hurt if they attempt to repair the mixers themselves, but if I can restore/rebuild Italian racing motorcycles (and race them), I think I can tackle a mixer. These mixers don't deserve to wind up in the metal recycling bin- help them have a new lease on life!
  • Anonymous Apr 28, 2008
    I need my N50 restored. One repair plac started to workon it and called me to pick up the mixer in a box after they started to take it apart. Wher can I take it or send it for repair.
  • AnneFtl Jul 29, 2008
    I have an original 1927 N50 and want to fix it up to look nice as well as work.
    I do not want my husband to even try anything with it unless he has
    the repair manual and Hobart will not even talk to me about a repair
    manual. Can someone help us ? Thanks, Anne
  • 640 Answers
Im a hobart service tech and service these mixers alot.the usual suspect problems is the tumbler assembly.service manuals from hobart---good luck they dont release them.i can help you out,
Posted on Jan 19, 2008
What a load! If they REALLY cared for consumer's health and well being, Hobart would put out the information as to how to do it right, rather than have folks just tear into the mixers and put the back together any old way.
What they really want to protect is not consumers, but outrageous repair margins.
I'm OK with that, but have the integrity to call a spade a spade.
Posted on Feb 06, 2008
Buy a new 1
Posted on Oct 30, 2008
6ya staff
SOURCE:
Hobart n -50 where do i put grease in, machine makes a grinding noise
If your N-50 is making a grinding noise there is a strong (almost certain) possibility that the cause is more than just needing more grease.
The sources of the noise are from the transmission case (front portion of the motor housing) and/or the planetary (where the blade attaches).
A search online should turn up the N-50 Service Manual.
With luck, it may be that the two adjustments specified in the Service Manual will do the trick
Three things come to mind regarding the noise:
1) If simply greasing the planetary does not do the trick, then
2) There are two adjustments to the transmission detailed in the Service Manual. And if that is not the cure
3) The transmission housing will need to be removed to find the source of the grinding. This is where the grease is truly encountered.
Sep 04, 2017 | Hobart Food Mixers
Shifting on my Hobart N-50 mixer. I just pulled the switch/shift cover. yellowish-brownish grease in places, but a few gears looked dry. Tried shifting / no success.
You are in for an adventure. The first step is to find the N-50 Service Manual online and download it.
Trouble shifting speeds is rarely a simple matter of lack of grease.
If your mixer shifted before removing the switch plate, then there is a post that shift lever engages which in not being engaged properly.
On the other hand, if that is not the problem, the transmission case must be removed. Shifting gears involves moving the tumbler yoke assembly. If you are extremely lucky the yoke's spring has become detached and re-attaching it will be all that is needed.
Of course the spring will be in place and you will have to deal with all the grease and investigate the cause.
This is a good time to replace the old grease as well.
Mar 14, 2017 | Hobart Food Mixers
What oil should I use for the Hobart Mixer P660?
A good standard 90 wt oil is what is ok for the gearcase. This is an old email from a hobart service tech and they recomend a special oil ordered from them. So you can decide which you want to use. "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in [email protected] (412) 788-5380. Steve Davis Field Engineer -
Sep 23, 2011 | Hobart P660 Stand Mixer
Does the Kitchenaid Model G / Hobart N-50 have a motor capacitor?
There does not appear to be one listed in the service manual. The manual is here Hobart 50 Service Manual
Jan 30, 2018 | Hobart N50 Stand Mixer
N-50 service manual
Hobart keeps there service manuals for their techs only and do not provide them to the general public,Give me a little time and a fax number and ill see what i can do.
Dec 14, 2008 | Hobart N50 Stand Mixer
Hobart N50 repair books
parts books are available at hobartservice.com for free and you might be able to find service manuals on ebay
Oct 22, 2008 | Hobart N50 Stand Mixer
Mystery part to a 1950 Hobart N50 Mixer; serial number 997185
Go to www.hobartservice.com, register, then go to select "food machines" in the Product Group, then "mixers"and look for the Discontinued Products, then find the N-50 mixer drawings, they are all there, even the old ones. Look through the "exploded" drawings for your extra parts. It seems to me that the tech who put this together should know if they belong to this mixer or not. Does he work for Hobart? Or is he a repair person who states that he knows how to repair Hobart products. If he does'n't work for Hobart, these parts may have been on his bench BEFORE he looked at your mixer. A true Hobart Tech has access to specs on ALL models and the ability to access the Service Manuals. If you find this solution helpfull, please rate it. ricardok45
Aug 20, 2008 | Hobart N50 Stand Mixer
N 50 here also
I apologize but im unable to answer yours or any others at this time.Ive been hijacked by another user on this site that is dropping my rating.I contacted [email protected] (manager) of this site about restoring my account but has yet to do so.If my request fall on deaf ears maybe if you can email1.gif him and explain that its hard to get info on any hobart products and im the only one that is a hobart tech answering questions for FREE!!As soon as this matters resolved i will continue to help people as ive been doing for a year on this site.
Mar 29, 2008 | Hobart N50 Stand Mixer
N50 with loud noise in operation
if you just had it serviced i would take it back to them.heres the site for an exploded parts view. http://www.hobartservice.com/Manuals/ to repair this yourself is a task if your not familiar with this mixer.i work for hobart and can give you any other info you may need.
Dec 16, 2007 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
410 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
