Question about Canon imageRUNNER 8500 Copier
Canon imageRunner 105
I have an error code of E000542-001 what is this and how can I fix and reset the unit?
  • Anonymous Mar 14, 2014
    i have a problem about imagerunner 105 error code is 000065000
  • Canon Expert
  • 287 Answers
Hello PE. I will tell you what the code means and although we can reset the code, if the PROBLEM still exists I am afraid the code will of course return when the copier performs a diagnostic. By telling you the reason for the failure perhaps you can fix the problem and therefore MR. COPIER wont be pissed. :-) This code means that the paper supply referred to as tray "B" has a problem.The lift motor for that paper supply could not (or the copier believes it could not) successfully lift the paper to the correct paper heighth required to feed the paper. This explanation may help you correct the problem.Now to clear the code. On the operator control panel next to the nine key pad is a button that says "additional functions". That button will be part of a 3 step process. Press the the additional function button>>>> next press the numbers 2 and 8 together at the same time>>>> then back to additional functions button.This is a 1,2,3 process that should be executed in a smooth but timely fashion. This will bring up a new window on the screen. Ther will be several "blocks" on the screen and one will say COPIER. Press copier.Then a new screen appears with several tabs across the top. One of those tabs will say FUNCTION. Press function.The screen will be filled with an assortment of blocks and one will say CLEAR. Press clear, and a new set of blocks will appear.One of the new set will say ERR. Press err and then in the lower right hand corner you will say a block saying "OK". Press ok. Now unplug the machine and wait a few seconds and plug it back in.You WILL have successfully erased the error code and the machine will perform its power on diagnostic as if nothing was ever wrong. However if the problem still exists the copier will see it and the code will return. If it does, you can perform the process again but this time pull tray "B" out so the copier cannot run a diagnostic on it. This is merely a workaround and will allow you to use the copier and its remaining paper supplies. As to what specifically the problem with paper tray "B" is could be several things, all of which would require a tech to come out. I must assume that is what you are trying to avoid (as would I ....$$$$$) I hope this helps you and I wish you the best. SPINAL
Posted on Jan 19, 2008
Erro code e000086-0000
CANON IR 105 ERROR CODE E000086-0000
May 26, 2014 | Canon Imagerunner Ir 105 Copier Printer...
Hi every one.i have canon copier ir105 gives me error code e602-102. I replaced hard disk ,after that the machine gives me error code e000744-2000 please if any help thank you
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Nov 21, 2010 | Canon imageRUNNER 105 Copier
Imagerunner 5000s with an error code e000014-0000
this is fixing motor fault
you need to replace main power pcb, fixing motor or dc controller board
you can not reset this error
Mar 31, 2010 | Canon imageRUNNER 5000 Copier
Our Canon ImageRunner 5000S shows the Error Code E000003-0000
this error is related to fixing unit,to reset error:* with head 2&8 together* with head LCD display change press COPIER> Function>Clear>Err>OK switch off/on the machine,if the error return check the AC supply unit or you have to call your service provider
Jul 22, 2009 | Canon imageRUNNER 5000 Copier
Im getting error e000000-0000
ok the Error code is to do with your fixing unit, you need to go into service and clear the error then reset machine should work again.
do a search for clearing fixing unit error code on your canon copier, wont be to hard to find
canon copier tech
Mar 30, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Have you recently changed or added a new toner resently?? If so try to reinstall it or add a new toner. A E00020 is a toner desity problem. It may be a bad toner cartridge..
May 11, 2008 | Canon imageRUNNER 105 Copier
Canon imageRUNNER 8500 Copier Logo
240 people viewed this question
old marine
old marine
