Check the battery: Make sure the battery is fully charged and properly connected to the scooter. If the battery is low, charge it fully before trying to use the scooter.
Reset the controller: Turn off the scooter and disconnect the battery. Wait for a few minutes, then reconnect the battery and turn on the scooter. This should reset the controller and may fix the issue.
Check the freewheel lever: If the freewheel lever is engaged, the scooter will not move. Make sure the freewheel lever is disengaged before trying to operate the scooter.
Check the throttle: If the throttle is not working properly, the scooter will not move. Make sure the throttle is fully engaged and that there are no obstructions preventing it from moving.
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
hi Shane, i recommend you check the fuses on the tiller ..
if all okay check the fuses located on the battery leads , if fitted and check the connections to the controller which is located under the foot panel..
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
The 5-beeps indicates you are in free-wheeling mode. If the free-wheeling brake disengage lever is in the correct position then you likely have a bad brake switch or bad brake coil assembly.
Verify free wheel lever is in correct position and Replace the bad component if necessary.
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
When the motor is screeching and draining the battery, that indicates that the motor has most likely seized up and is not turning the axle properly, which in turn will drain the batteries quickly as the scooter struggles to move. I strongly recommend discontinuing use of the scooter for your safety until the motor can be replaced; contact the manufacturer for a service call to fully diagnose the problem and give you a quote. If your insurance purchased the scooter for you, they may partially pay for the repair. Good luck!
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
