Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
How to reset lamp timer
Have replaced lamp, need to know how to set lamp timer.
  • mjpalm May 11, 2010
    CTF, are you sure this is proper solution ? I cant get it to work...
    President:
  • 4,402 Answers
Press and hold the "enter" button on the TV, the press and hold the "menu" button on the zenith remote-- after several seconds of holding both buttons the option of re-setting the lamp came up. Hope this helps
Posted on Jan 18, 2008
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Tip
How to reset the lamp timer on Sony Projection TVs.
If you have replaced the lamp in your Sony projection TV you must reset the lamp timer to get rid of the message saying that your lamp needs to be replaced. Let's face it, you know you already accomplished replacing the lamp but the TV isn't smart enough to know that. I will explain in detail how to accomplish the reset procedure.
Resetting the lamp timer is a complicated procedure but you should be able to do it if you have plenty of patience and know how to follow instructions. Read the procedure over first several times before trying to do it and locate all the buttons on the remote. You may want to try the procedure on the remote to make sure that you have the sequence memorized.
By the way the lamp life is figured to be from 5000 to 8000 hours. That is not much time if the TV is being used for more than 8 hours per day. If you do the math and watch your TV for 8 hours per day (not uncommon) the lamp will need replaced in 3 to 5 years. So be ready to do this procedure again in the very near future.
Here is the procedure.
All commands should be done using the factory remote:
1) enter the service mode by pressing display, 5, volume +, Power on
2) press JUMP 3 times
3) to display the time press channel 2, 9 times
4) to reset lamp timer press channel 3, MUTE, Enter
5) to check the time press channel 1, 7 times
6) when complete turn set off to exit.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 30, 2010 | Televison & Video
Hey i just replaced the lamp in my jvc 61' tv and needed to know how to reset the time
Scroll down the menu till you see "Lamp Reset " press Enter and your done..
Apr 22, 2010 | JVC Televison & Video
I just replaced a lamp and don't know how to reset i have a panasonic multimedia projection hdtv model# pt-44lcx65-k/ pt-52lcx65-k/ pt-61lcx65-k. i bought a lamp unit part # pt-52lcx65 for my tv
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
asnowman
Dec 05, 2009 | Panasonic Televison & Video
How do i reset the timer
go to the menu, find lamp settings then select, lamp counter resit. confirm.
Oct 22, 2009 | Sanyo PLC XU50 Multimedia Projector
The person I purchased this t.v from is saying the lamp was just replaced, but the FINAL WARNING REPLACE BULB AND RESET TIMER message pops up every time I power the tv on. She said she forgot to reset the...
If the timer has not been reset telling the unit it has a new lamp you will get that message. Call a servicer to find out how to reset the timer if you don't have the owners manual. If the message continues after that you will need to purchace a new lamp. There are problems that accur with some aftermarket lamps.
Sep 21, 2009 | Televison & Video
Need to reset lamp timer
The lamp timer expiring would not shutdown the unit typically. Purchase a replacement lamp and included will be the instructions to both replace the lamp and reset the timer.
Dan
Apr 15, 2009 | Mitsubishi ES100U Multimedia Projector
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
993 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
