Question about Motorola Mobility RAZR V3
Indicator unknown At the top of my phone there is an indicator next to the signa strength. Not sure how to explain it. There is a light blue box with two darker blue boxes with points, one on the top right corner pointing down and one at the bottom left pointing up. Please help.
    Scholar:
  • 117 Answers
The is the bluetooth icon.
Kinda looks like two side ways triangles stacked on top of eachother. GO into your settings and turn it off if you dont wantto use it. Bluetooth will drain a battery.
Posted on Jan 19, 2008
How do i connect my ipad to the hello kitty keyboard
After turning on your keyboard, the blue indicator light will come on for a couple of seconds, then go away. Next, press the button that says "connect" at the very top right corner of the keyboard. It looks like a wifi signal with a circle around it (I had trouble with this part, I didn't realize it was a button). Blue indicator light will start blinking, meaning that it's ready to connect. Go to Settings > Bluetooth (make sure it's on) > click on device. Voila!
Nov 29, 2012 | Hello Kitty Portfolio Case and Bluetooth...
What is wrong when the signa lights stay on and the lights in the car and doors flash on and off while I am driving?
The door closed indicator switches could be malfunctioning. This could be due to the fact that they have accumulated dirt in them and do not release properly.
Another cause could be a short circuit due to a worn wire housing.
Feb 26, 2011 | 1997 Jeep Grand Cherokee
Top two lights come on.. next to engine light
Check your owers manual you got with the trail blazer, it will explain what the two indicator lights are.
good luck.
Jan 24, 2011 | 2006 Chevrolet Trailblazer
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
My LG Chocolate phone is in mute and I cannot get it out of it. Cannot hear any sound out of earpiece...can only use if it is in speaker phone mode...have I changed the setting somehow....is there a way to...
Not sure if this will help you, but when you slide the phone open, do you see 4 red lit-up indicators surrounding your center data wheel? On mine there are:
Red line - top left
Red line - top right
SPK - bottom left
CLR - bottom right
(Note that the indicators stay lit for about 20 seconds)
The indicator at the top left is the MUTE On/Off switch (you will see "MUTE" in the main display, just above the top left indicator). Although there is no real 'switch' there, you just push on that red indicator. It should vibrate when you turn MUTE on or off.
If the indicators go dark, the switch stops working. In that case, you have to slide the LOCK switch (this is a real switch, on the right side of the phone...it's the middle thing - above the MUSIC switch and below the micro SD opening). Just slide downwards and let go...the indicators should light back up, and you can use the MUTE switch then.
Hope this helps.
And BTW, the reason I am answering this question is because despite all I've just explained, my Chocolate MUTE swith, and all those indicator switches, have recently become intermittent. Which means when I am on an important call, after I switch to MUTE I find I can't get it out of MUTE. So if you try the above and it doesn't work, maybe your phone has a problem like mine....
Jul 07, 2008 | Cell Phones
Unknown icon/symbol on the screen
My w850i has a blue sqaure at the top with a cartoon woman inside with an arrow pointing forwards and i dont no what it is
May 19, 2008 | Sony Ericsson W850i Cellular Phone
BLUE TOOTH CONECTION PROBLEMS
take it to the store where you bought it from and ahve them assist you with it.
Mar 03, 2008 | Samsung SGH-D900 Cellular Phone
Motorola Mobility RAZR V3 Logo
89 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
