Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Tv won't turn on
The power light is solid red. When I push the button it will not come on. My tv is connected to a JVC receiver. It is on, the cable is on, I have sound but the power light on the TV will not turn green. The lamp indicator light is not on, the temp light is not on. I can't turn in on manually or with the remote.
    President:
  • 4,402 Answers
Http://www.petitiononline.com/panbulb/petition.html
repair technician and he confirmed that the Ballast is defective and causes the bulbs to blow out prematurely in many of the sets manufactured in '03/'04. BTW. Panny will pay to replace the ballast, if defective, even out of warranty.
http://forum.ecoustics.com/bbs/messages/2/14473.html
Posted on Jan 18, 2008
Why would JVC 8010 optic digital randomly malfunction?
I don't know if this helps but, if you have your bluray hooked directly to your tv some times TVs can have issues sending the proper channel to audio out to the receiver. You should always connect your bluray and other devices directly to your receiver.
if that's not the case,
Try turning the tv speakers back on, test the bluray hooked directly to the tv and see if things work flawlessly just with the tv and bluray.
If they don't there may be something just wrong with the cables.
If they do work flawlessly then there may be something wrong with the receiver.
If you already had your bluray connected to the receiver, I would still try direct to tv test and swapping cables.
The randomness leads me to think cables. But you can rule them out by testing directly to TV.
I hope that helps
Sep 06, 2014 | JVC Audio Players & Recorders
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
Tv will not turn on, it has a solid red light
Mine too. I pushed and held the power button in at which point the red light turned off. I then pushed the power button and the tv came on and is working fine. I hope this helps you. Good luck.
Jan 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 15, 2009 | JVC AV-35750 35" TV
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
