check whether your phones display is working or its fault.if your phones disply is ok i think your phone software may be corrupted.Please reinstall your phones software.
The problem is from the ribbon that attach the screen to the main board of the phone, it is not properly connected that is why you do not have display. If the phone should have fallen, then the screen might be faulty. If it did not fall from you, then it means the ribbon of the screen is disconnected from the phone.
First, try to flash the phone, then you open it up carefully. And sit the ribbon that links the screen to the main panel of the phone properly.
And if that does not help, then you need to replace the screen of the phone.
press on/off switch of ur mobile now remove ur battery and reinstall the battery without releasing the on/off switch. repeat this 3-4 times....without releasing the on/off switch,,, and if it doesnt help......go for software update,,,
first you have to press the menu button then immediatly press star symbol button. or soft one key press first then it shows in disply screen which is the unlock button, you have press that.
