Question about Apple iPhone Smartphone
Cannot connect to Youtube
Have a unlocked version of iphone i have been able to use safari and other features over EDGE network but when i try to connect to Youtube it says "cannot connect to Youtube"
AND I HAVE DO : First,I get this http://soundsgood.cocolog-nifty.com/blog/files/youtube.zip
after I extract this file, I get three files. then I SHOULD put them in the /var/root/Library/Lockdown/ with WinSCP or some tools.
And I SHOULD reboot MY iPhone, then Youtube should be worked.
BUT THE PROBLEM IS I DO'T KNOW HOW TO PUT THAT TREE FILES in the /var/root/Library/Lockdown/ with WinSCP or some tools
  • BRIK Jan 20, 2008
    hey vijay thank you for your help man but i did't understand yet how to copy them and where or what is winscp can u explan more please
  • themastadr Feb 24, 2008
    wen i download the 3 files how do i put em in the iphone ???
1 go to winscp..2 open application 3 find youtube.app..open it then 5 select all files right click open properties 6 change octal to 755...exit
Posted on Feb 05, 2008
Go to http://limitededitioniphone.com/windows-guide-to-using-winscp-with-iphone/
there is very detailed instructions and link with winscp download!
It just helped me!
Posted on Jan 31, 2008
Hi This is vijay from india, just copy all these three files and with the help of Winscp overwrite the existing ones. it will work. in my case it is working alright.
Posted on Jan 19, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: i try to connect to Youtube it says "cannot connect to Youtube"
I FINALLY GOT YOUTUBE WORKING on 1.1.4...
Step 1: backup your settings and files on itunes
Step 2: restore iphone to default( this will erase everything)
Step 3: try Youtube before Jailbreak to make sure its working
Step 4: ***important*** run ziphone for JAILBREAK only!
YouTUBE remains working. when I tried to DO-IT-ALL youtube never worked afterwards.
Step 5: Sync iphone to get your settings, contacts, emails back
Posted on Apr 07, 2008
Can't connect to YouTube on 4.2.1 version it's been jailbroken too
Make sure you are connected to the internet. Go to Settings>General>Network>Enable Cellular data (for iPhone) For iPod Touch, make sure you are connected to an operational WiFi network. You can do this by just going to the Safari application for example and doing a google search to check and see if you have a usable connection. If these do not work, quit the running apps by double clicking the home button then holding down an icon at the bottom of the screen then exiting out of the apps one by one. If this does not work, restart your iPhone or iPod Touch (it is okay to restart because the jailbreak on iOS 4.2.1 is untethered, meaning you can turn off your device without having to re-jailbreak) Try to open youtube when the device turns back on. If this does not work, go to Safari and search "youtube mobile" and click on the first link. This will direct you to the browser version of YouTube. Once on that page, tap the + button at the bottom to add this page/link to your home screen. It will function like the regular YouTube app, and in my opinion, its faster.
Mar 07, 2011 | iPhone Apps
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
http://support.apple.com/kb/ts2756
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | Opera Software Mini
Jailbreak iPhone edge os3.1.2
I have a perfect solution for that!
You just need to install Push Fix from Cydia. Click here to see the step by step instruction on how to do that.
For more iPhone / iPod touch tips, click here.
Mar 07, 2010 | Apple iPhone Smartphone
I have a unlocked version of iphone i have been able to use safari and other features over EDGE network but when i try to connect to Youtube it says "cannot connect to Youtube
I had just the solution for you.
Click here to see the full instruction including a video showing how the process works. You will be able to fix this problem in no time.
Jan 31, 2010 | Apple iPhone Smartphone
How to unlock the iphone and nokia
Unlock:
- 1st Generation iPhone (up to version 3.1.2)
- iPhone 3G (up to version 3.1.2)
- iPhone 3GS (up to version 3.1.2)
Jailbreak:
Features:
- Use any GSM Sim card worldwide
- Jailbreak
- Custom ringtones and wallpapers
- Third-party applications
- Enable full iPod capabilities
- Safari, YouTube, Google Maps, Notes, Photos, E-mail
- WiFi/Edge Connection
- And a lot more ..
http://www.3gsiphoneunlocking.com/
Nov 07, 2009 | Apple iPhone 3G
Youtube not working
The youtube app on the phone is provided by the network (original provider of the phone) so unless t-mobile provide that (and other services) you can't use it... but you can connect to the normal youtube by using safari it just wont be optimised for the iphone like the app is
Sep 27, 2008 | Apple iPhone Smartphone
Enabling Edge
You need either GPRS enabled with your SIM card or WI-Fi enabled.
For GPRS enabling, go to Settings ->Network->EDGE->APN -type your SIM Card GPRS site address, ask your SIM provider for the details. Username-put your phone number with country code and Password-put what is there for your SIM.
For Wi-Fi enabling, go to Settings -> Wi-Fi-set it to ON and it would automatically search for nearby connections. If you find one unlocked, just select that and start using internet via SAFARI!!!
Jul 02, 2008 | Apple iPhone Smartphone
I try to connect to Youtube it says "cannot connect to Youtube"
Jan 18, 2008 | Apple iPhone Smartphone
Cannot connect Youtube on iphone
Oct 08, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
219 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
