Laptop i done a system restore on my laptop,when it booted back up it wount go past windows saver ,windows xp comes on the it says,tjis applivation has failed to start because WININET,dll was not found.re-installing the application may fix this problem, and it wount go a futher, can you please help me
    Genius:
  • 1,601 Answers
You had a virus in the restore files.Restoring it brought it back.
Do you get the same error in safe mode?
Posted on Jan 18, 2008
Error 380394-26-2A0444D9
try to restore your system using system restore
Run --> msconfig --> System Restore...
Find a date back in the past where the system was working. What you can also do to test to see if it's windows with out loosing your files, partition like 10 gb and install windows xp, boot into the partition windows xp and try to burn a disc. If all works we know it's windows what you can try is reinstall your drivers for the driver or do a system restore or reinstall windows, BACKUP first. If it's windows then you can delete the partition 10gb to get back the 10gb for you to use again. If all was working awhile back and you know the date and all the programs you might of installed since then. Go to Control Panel --> Add/Remove Programs --> Find all installed since then and remove them.
May 24, 2012 | Computers & Internet
Factory settings restore on dell inspiron 1525 windows vista
Resetting a Dell Inspiron to the factory settings allows the user to restore the Dell Inspiron to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Get the step-by-step how to guide..http://technical-support-squad.blogspot.in/2012/08/dell-inspiron-how-to-factory-reset.html
Feb 12, 2012 | Dell Inspiron 1525 Laptop
After booting up samsung NC10 error message saying windows could not start because following file missing/corrupt \windows\system\vgaoem.fon
OK, try, Boot Up in SAFE MODE, press F8 At Boot up, quickly, select, Boot to safe Mode desktop, with networking... simply copy vgaoem.fon file from xp disc or from net, paste file into windows system folder, done.
OR You could simply perform a system restore back to another time BEFORE you had a problem, again start up in Safe mode, F8. but this time when the choice is given to choose safe mode desktop or system restore, choose system restore, when a calendar like thing is displayed choose a time PRIOR to this problem happening, follow instructions and before you know it your PC will be back.
Oct 15, 2010 | Samsung Computers & Internet
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Windows xp boots but the desktop will not come up
Log in using SAFE MODE. While laptop boots, press F8 and it will prompt for which mode to login. Select 'SAFE MODE'. Once logged in try to restore the OS to a previous good restore point.
If you've a backup of the registry key, it will help better. Just restore the registry from the backup instead of going for an old restore point.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification. Thnx
Apr 01, 2010 | Computers & Internet
My HP Mini 1000 XP will not restart, it gets stuck on the Windows XP welcome screen
Press F8 during boot this will take you to boot options select "Last Known Good Configuration" or select Safe Mode to perform a system repair.
To repair your system follow the steps below
1. Click Start and open Run on the Start menu.
2. Type (or copy and paste) C:\WINDOWS\system32\restore\rstrui.exe in the Run box.
3. This will open System Restore now select the first option (restore my computer to an earlier time) and click next.
4. Select a date when your network last worked and complete restoration.
Do not worry about selecting the wrong date you can always undo any restore within system restore you will select undo last restore.
Jan 12, 2010 | HP Mini 1000 Netbook
Loading PBR for descriptor 2...done
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Toshiba satellite P205-S6337 screen saver has never come on
either the screen saver is corrupted or it is not supported on ur os,
if problem persists make these 1> system restore or 2>repair ur os or 3>format ur system (do it one by one if not resolved)
Feb 02, 2009 | Toshiba Satellite P205-S6337 Notebook
Black screen with cursor acer aspire 5315
start your laptop in a safe mode by pressing f8 during booting, the restore your system to a back date where its working fine
Sep 30, 2008 | Acer Aspire 5315 Notebook
I have a blue screen saver cant get rid of it
firstly download a good anti virus and spyware programme for example AVG 8 Free.
Antivirus 2008 needs to be removed in safe mode (press F8 on start up) and select start windows in safe mode, choose windows XP, then choose the administrator account and the run the anti virus then restart your pc
Aug 17, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
