Question about Samsung HCN529W 52" Rear Projection Television
Samsung tv the tv is on but there is no sound it chips in and out on its own now there is no sound at all
I have 52"or 53" HCN529 projection tv . when you turn on it chirps to alert it's on but blank screen but i can tell it wants to turn on by the whiteness in the top corner of the screen it also keeps making the chirping noise by itself like it wants to start but nothing. when it chirps then i can push the button to turn completely off.
Posted on Jun 07, 2008
    President:
  • 4,402 Answers
Could be the cooling fan
Posted on Jan 18, 2008
Ideas on parts to replace?
Here's the test. With the TV on shine a flashlight on the screen. If you can see a dim picture the backlight circuits are bad. If you cannot see a picture the T-Con board is bad. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 12, 2016 | Samsung Televison & Video
Samsung TV
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
Aug 07, 2016 | Samsung Televison & Video
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
Jan 01, 2016 | Samsung Televison & Video
Shut off and turn on TV Problem
Sounds as though you have a power supply problem. Check the TV cord for a weak soft spot to make sure the cord isn't cut or burned internally. Either that or the chip that controls the switch on and off may be failing inside the TV, in this case you may have to remove and replace the chip yourself by unsoldering the old chip and soldering the new chip if you are not electronically challenge.
Sep 24, 2012 | Samsung Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
Samsung dlp tv picture turns off sound stays on
Hello
Check whether the lamp life hours are going to be out. Refer to its user manual for details. DLP chips fault is very rare; unless you have handled them very carefully. Check the lamp and BALLAST baord that supplies voltage to lamp.
Picture of the ballast baord to your TV is attached.2_29_2012_10_35_36_am.jpg
Feb 29, 2012 | Samsung HLR5087W 50" Rear Projection HDTV
Samsung TXG2547 25"inches TV problem
you have damage your tv micro chip, regulator ,or horizontal output with static current when you plug out your tv from th plug,what is clicking is the relay trying to power up your tyv but due too the damage it cannot power have a tech repair your tv good luck
Oct 26, 2008 | Samsung TXG2547 25" TV
Samsung HCN529W 52" Rear Projection Television Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
