My American amp stopped working when I plugged it in in France
I brought my Dean Markley practice amplifier to France and just tried to plug it in today. There was a loud popping sound, and then the amp wouldn't work anymore. I was using a universal adapter at the time, which I've used with other electronics with no problems, so I don't know why my amp died. Did I blow a fuse because of too much electricity?? I just want to practice my pedal steel!
    Genius:
  • 1,067 Answers
Ya proably did usaly those set up for 115 v olny when u go to france ther power goes up and down not as good as us in usa ok proably blew transfomers in it best bet is to get nice amp in france made for them like arolnad jc40 60 u like that small clean warm
Posted on Jan 18, 2008
  • 1 more comment
  • Experi Oct 28, 2013
    US power is 115v, 60 Hz. In Europe (inc France) it is 230v, 50 Hz. So you will have blown the amp by plugging it into a voltage twice what it was designed for.
    The frequency differnebe probably will not matter for an amplifier (but it does for other devices such as thiose with motors - they will run slower in Europe, even when used through a voltage converter).
    Modern small items (mobile phones, tablets, laptops) often come with a power supply that will cope with either US or European voltage and frequency - read the label carefully, they will often be marked as 110-240V, 50-60Hz, then you are OK with just a simple adaptor plug. Some other devices (eg some desktop computers) have a switch or similar on the back that you can set to work with either US or Eurpopean voltages.
I have gotten an amp for my guitar..It worked fine the first 2 day...when I went back to it today...it was not working...could it be my guitar?
Hi Deb:
A couple of ways to check:
1) Plug your guitar into a different amp and see if it works.
2) Plug a different guitar into your amp and see if it works.
3) Try your guitar on your amp but use a different cord.
I'd be betting that the nearest music/instrument store would be quite happy to check your equipment for you, and most reasonably experienced musicians would likely volunteer to help. I know I would if you were my neighbor.
Cheers.
Dec 30, 2015 | Dean Guitars Music
Brought this amp a while ago, was working great and recently it stopped working. when i brought it to a stereo store( 2 different ones) they both said ," it's getting power in, and shows on an amp reader...
What do you mean it's pushing out? A common place for failure is the connection between the plugs and the board, usually the RCA plug. Set the thing up, make sure your using good RCA wires. (Check them on a working system.) Then start putting slight pressure on the plugs in different directions. Do this slowly and you might get sound. My overall experience with amps is when they start acting up, just go get another one. The money and effort put in to fixing them is just not worth it.
Nov 02, 2013 | Coustic Car Audio 321QE Car Audio...
Issues With Dean Markley ProMag Plus Acoustic Pickup
Hope you didn't throw it out. I know this is a bit late.
Cleanly remove about an inch from the end of the cable.
Loosen screw in the jack (yeah, it's there on the side).
Put cable back in jack and push it till it won't go anymore.
Tighten screw. You need to tighten enough so screw will breach the insulation and make a ground connection.
Oct 12, 2012 | Dean Markley ProMag Plus Acoustic Pickup
I have a dean markley promag grand acoustic pick-up which connects to a plug in stap button. when i plug in there is no sound unless the volume is turned up on the amp to the max and then a very faint...
The output of this is fairly low. Do make sure you have steel strings rather than bronze for magnetic pickups like this. Make sure this pickup is oriented per the instructions.
Jul 02, 2011 | Dean Markley ProMag Grand Guitar Pickup
My guitar was playing fine yesterday but when i plugged it in after my friend's bass guitar was using the same amp, my guitar got this feedback from the amp. I cant stop it and it's very problematic.
First of all I suggest that you try your guitar through another amp you know works without the feedback. There is a very slim chance there is something wrong with your guitar but I would say no. You didn't mention what kind of amp you have: solid state, tube or hybrid. It would help if you tell us what brand and model number your amp is. Try setting your amps controls the way you usually have them and using a long cord that works properly, isolate your guitar by putting it in a room with the door closed by running the cord under the door. Is the feedback still there? Try playing with your back to the amplifier. Is the feedback still there? You need to identify the problem. Is it your guitar or is it the amp? Here is a link to tube amp troubleshooting:http://www.geofex.com/ampdbug/ampdebug.htm Here is a link to guitar feedback causes:http://www.guitarsite.com/discussion/messages/23765.shtml If you decide it is your guitar you can have a look for broken solder joints etc. There are wiring diagrams on the internet. If it is your amplifier, you should take it in to be serviced. Take it to a dealer that carries and services that brand. Unless you have all the tools, a schematic and electronic troubleshooting experience you are in danger of injuring or killing yourself or making the problem worse. Hope this helps.
Nov 07, 2010 | Dean Guitars Dean Ml Xm Electric Guitar
How does my bass boost remote for amplifier work
there is a slot in the amp for the one end of it it looks like a phone jack plug it in but the bass boost is asking your amp to create more power then it can so be careful with it
Apr 01, 2010 | Legacy - American II: 2 Channel 2000W...
How do i plug my eletric guitar into an amp
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Oct 02, 2009 | Dean Guitars Dean Ml79 Electric Guitar
My amp won't play sound without headphones plugged in
Hi..
1st off ,check the wire to the speaker. If that's ok then your headphone jack is broken inside. Peavey and others use cheesy headphone jacks.
Jan 11, 2009 | Peavey Audio Players & Recorders
1/4 input jacks for guitars
nope....if you go to your local music store they should have an adapter for your situation.....it will cost approx. $10-$20 (depending on the company)
Sep 15, 2008 | Tascam 2488 Portastudio Multitrack...
81 people viewed this question
 Grubhead
Grubhead
