Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Centralized gas heater
My Heater is starting to make more noise than usual when it starts up. This is before the fan turns on. can you help me?
  • 26 Answers
Pls check the following,
1) Check the NamePlate of the units base to input Power supply voltage (when the voltage is low your unit hard to start its so hear sound noise before to start).
2) Check the wiring connection if this is inverted.
3) Check the connector wire to Compressor/F.m.may be loose.
If this not solve go to the nearest repair shop to check the compressor if this is internal problem.
Thanks & best regards,
Posted on Jan 19, 2008
I have takagi TK3 tankless water heater humming and rattling noise issue at start up.
Sounds kinda lame, but check every nut, bolt and screw on the heater and where it fastens to the wall. something may simply be loose!
Apr 01, 2017 | Water Water Heaters
My Reddy heater torpedo multi fuel heater won't start this year. It makes a loud humming noise for a minute or so and then nothing. If I try starting it a few times in a row it will make the noise...
Remove the top cover and rotate the fan by hand. If should turn pretty easily. If not may you can put some oil where the shaft passes through the ends otherwise you will need a new motor. If the fan turns easily then the capacitor is probably shot. I don't know if you can get the capacitor seperate from the motor or not. There is a small low pressure compressor attached to the back of the motor. Your problem may also lie in there. The covers come off easily so you can check it out.
Dec 29, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Rheem 40 gal power vent gas water heater shows code 42
you plugged it in and the fan started or you unplugged it and the fan started,,the fan will come on first before the unit will inginte to take out the excess gas, if it didn't lite then the ignitor might not be working there are 2 swithces on the unit one on the fan and one by the gas valve make sure they are both on and make sure the gas it also turned on.
May 30, 2009 | Water Heaters
Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Mar 16, 2009 | Water Heaters
150,000BTU kerosene heater won't start,just buzzes.
Your starting capacitor is bad. It's usually mounted on the side of the motor. If not, it's the thing that the motor wires go to from the end of the motor. Usually, less than $10.
Feb 12, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heater making angry noise!
Your heater fan bearing is shot,,time to replace Fan now before you really need it.
Jan 19, 2009 | 2004 Mazda 3
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
23 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
