posted by MizoSoup on Jan 18, 2008
dsl connection to the router with 1 desktop windows xp and 1 laptop windows vista and the connection drops for 10 seconds every 5 to 15 minutes when both online
Comment by MizoSoup, posted on Jan 19, 2008
yeah but the router don't drop only the dsl modem so what do think the problem is?
Best Solution
posted on Jan 18, 2008
You router needs to be replaced,, When it gets loaded, it resets itself as it isnt capable of carrying the load.. if you look at your ip when this happens you would have realised if your ip changes.. You can try resetting the router first but if that fails you will need to replace the router..
Comment by DARKLORD1, posted on Jan 19, 2008
the router :)
Try resetting the modem and the router, and changing the connection cable between them,, but Istill believe the router is the problem, to verify this connect the dsl model to the computer directly and you will see it works fine..
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP Compaq Thin Client T5300 (dc643a#aba) Network Terminal
HP Compaq thin client t5510 (PC539TABU) Network Terminal
HP HP Thin Client t5135 Eden 400MHz/64MB Flash/128MB RAM, HP ThinConnect (RK271AA#ABA) Network Terminal
HP HP t5720 NX1500 F1GB/R1GB XP Embedded SP2 Thin Client (AH461AA) Network Terminal
HP HP Neoware e90 Thin Client VIA Eden 800MHz/1GB Flash/512MB RAM/NIC/XPe Network Terminal
HP HP t5135 Thin Client - Thin Client - VIA Eden 400MHz - 128MB RAM - 64MB Flash - HP ThinConnect Network Terminal
HP EVO T5700 (dc640a#aba) Network Terminal
Can you Help with these Network Terminals problems?
Neoware Systems c50 Thin Client Network...
Printing to a local device...
I use a thin client to access a... Answer This...
NComputing L230 Network Terminal
NComputing L230 won't connect...
The host Console says Waiting... Answer This...
WYSE Winterm S30 Network Terminal
Ip addresses and Gateway...
I use the hardware reset but it... Answer This...
WYSE 9150SE (90208802) Network Terminal
Unable to login into Connectio...
I have a WYSE terminal in one... Answer This...
WYSE Winterm 3150SE Network Terminal
reconfigure winterm
reconfigure winterm
I have forgoten the user name... Answer This...
Repair Service
Find Network Terminal Repairman Near You:
