Question about Whirlpool LER5636P Electric Dryer
Dryer not heating up
My Estate by whirlpool dryer is not heating up. This is the second problem I have had with this dryer. When I put the dryer on 60 mins. it would stop once it reached 30 mins. and I would have to restart the dryer. Now the dryer is running but not heating up. We have checked the heating elements, no problems there. What could be the problem? I would like to do it myself instead of paying a repair man.
Thanks
  • jos916 Dec 19, 2008
    My Whirlpool dryer is not heating. It is not a vent problem. Could it be the pilot lite?
  • robert samples May 11, 2010
    have you check the voltage at your out let now i know its running but it will run on 110 but wont run and heat unless its got 220
    Scholar:
  • 163 Answers
Yup.. Same as a water heater.. Generally will run a constant 120V to the bottom Element and you can see 240 at the top and supply all day.. (Until the reset snaps).. Check for a Thermal and its probably the issue).. Snap disk in the shape of a football, Silver w/2-3 wires I/O.. Be careful if you dont work on 240V or electrical for that matter.(UNPLUG PERIOD)...Mine kicked out the other day when the main lost 120 and the house half quit..
Posted on Jan 18, 2008
What is the part number for the heating element in a whirlpool estate dryer 2406026-fm54?
There are different ones, so you need to disassemble enough to get a good look at it, then click on this link to repairclinic.com
http://www.repairclinic.com/Shop-For-Parts/a8b5c42-x776869726c706f6f6c2032343036303236666d3534/Whirlpool-2406026Fm54-Whirlpool-Dryer-Heating-Element-Parts
and order it. . . They also have movies here giving you some direction on replacing your element . . You'll save a good bit of money . .
Jul 20, 2014 | Estate EED4300TQ Electric Dryer
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer estate whirlpool not heating after changing thermal fuse what could b wrong
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
vxczvxc
Aug 31, 2010 | Estate TEDX640JQ Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryer spins no heat?
Inside the tub in the dryer itself is a heating element behind the screen. Try replacing it. Unplug the machine first though.
Aug 22, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
143 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
