Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Picture will not come on
When I turn the t.v. on it shows a blue line and yellow line horizontally in the middle then t.v. turns off. Please Help :(
  • RCA Master
  • 8,617 Answers
You have a component failure in the horizontal deflection circuit thereby sending the set into protective shutdown. It will have to go to the repair shop unless you have some basic troubleshooting skills and the service manual.Let me know if I can assist you any further.
Posted on Jan 24, 2008
When I turn it on there is just a horizenal line. This is on a Mitsubishi cs 35 ax 1 35" from 1992
hi there, it seems you have problem with your VERTICAL IC, this is similar to all CRT I have repaired. horizontal lines in the middle huh! well the picture is deflected in the center of the screen. it shows your TV is oscillating. means it is good. the problem is that you cannot adjust the picture to occupy the whole monitor. By replacing the Vertical IC it will remedy the picture to view widely. the vertical IC has these many 8-10 pins and mounted on heat sink. Usually mine is serial with LA 7837. good luck on your troubleshooting, hope this help, please rate and vote.
Mar 22, 2011 | Televison & Video
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
52 inch rca projection tv turn tv on and there are horizontal
Go to menu then setup look for convergence if you Do NOt see convergence then you have a open fuse FL231 Located on right side of FBT there is 3 in a roll small brown rectrangle looking caps but they are Fuses it will be in the one in the middle.
Aug 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
I have a apex GB5108 tv, the picture has become a red yellow and blue horizontal line in the middle of the tv. is it fixable
Thats vertical deflection failure . Check the solder on the vertical output IC and the Yoke plugs. If that doesnt help you may need a new Vertical IC
Jul 01, 2008 | Apex Digital Televison & Video
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Screen and volume problem
Hello, the problem regarding horizontal blue line can be around vertical output stage with IC(LA78045). Please check for cold soldering, resolder the suspected solderings. Best regards.
Apr 27, 2007 | Sony KP-46WT520 46" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
