Question about Whirlpool ET1FTKXK Top Freezer Refrigerator
Whirlpool Refrigerator model ET1FTTXKT03 w/ Top Mount Freezer
Light is on inside fridge, but no motor running and food beginning to thaw, spoil. No obvious solutions after removing backing on rear and tapping connections. Please help!
  • Anonymous Nov 17, 2008
    refrigerator not cold
  • 1,003 Answers
Posted on Jan 18, 2008
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
My whirlpool fridge/freezer model ET1FHTXM forms ice in the back of the freezer, and water drips down to the fridge. I can't figure out what is wrong. We do not have the water hose hooked up. Could...
Turn off or unplug the refrigerator.
Open the freezer.
Remove the food.
Remove the back panel inside the freezer.
Thaw the ice and clean out the defrost drain hole.
Re-assemble the freezer parts and turn it back on.
Jul 20, 2011 | Whirlpool ET1FHTXM Top Freezer...
Freezer isn't cool enough; my food is beginning to thaw. I can't find the manual to find out what I can do to trouble shoot.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Feb 14, 2011 | Whirlpool Refrigerators
The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
Could be defrost sticking or the compressor not starting...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a top refrig and bottom freezer. A maytag. It is 2 mo old. bought from Home Depot. The freezer defrosted and some of the food was thawed. I took everythng out and now the freezer is cooling. The...
You just caught it in defrost mode or the defrost is lasting too long or sticking on...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Sep 06, 2010 | Whirlpool Refrigerators
About a month ago we noticed that there was water on the food in our refrigerator and that ice was building up in the freezer. Today when i went to get ice cream out of the freezer I noticed it had...
I thoguht I had posted the solution. repeating now ask for estimates/ inference from thre persons and deccide for only low cost of repair. If your fridge is more than 5 years old do not proceed specially if the pumping of the compressor is down. Go for a good exchange with a the modern enerrgy effficient models as you can choose from good economic/ luxury ranges and give you about 5-7 years warranty.Invest Well. Good Luck
Jun 28, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
I have a tfx22zr and the door seals are warm to slightly hot at times. The fridge will not stay cold to the point of food spoiling at times. the freezer gets to the mushy freeze mode. I emptied both and...
One of two things either the condenser is dirty,that would be the black coil under the refrigerator,or the condenser fan motor is not running,that would be behind the refrigerator at the bottom behind the panel,at any time the compressor is running this fan should be running,if it is not,the compressor will run and cool somewhat but overheat often and cycle off causing fluctuating temperatures,the motor is easy to change and fairly easy to find on most GE units....hope this helps
Sep 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is not cold on top, but still cold on bottom.
Sounds as if you have a bad evep. Fan motor. It souldnt by over $40.00. And if the unit still look and works good other than this problem. It's located behind the inside back freezer panel. Diffaculty level in my opinion is a 5 out of a scale of 1 to 10. 10
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ET1FTKXK Top Freezer Refrigerator Logo
117 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
