Question about Skull Candy Headsets
New skullcandy audio ear flaps for giro bad lieutenant
The snaps are a different size and won't connect
  • 15 Answers
SOURCE: cracked green piece that holds earpiece on skullcandy headpones
This you can warranty. they will give you 1/2 off on a new pair but at least you can get that.
Posted on Aug 10, 2009
0 characters
1 Points
Broken headband
You can try to strip a little bit of the jacket off the wires and twist them together securely. Then use a little bit of electrical tape to wrap the bare wire. After, you can tape the head piece back together...... or you could buy some new headphones.
May 24, 2012 | AKG GHS1 Headset
Ear tip can NOT fit my ear ! it keeps slide out from my ear~ Dose anyone here have the solution for it?? is there any ear tip i can use to solve the problem ?? Thanks
Have you tried a different size ear tip, you should have gotten a small ab a large size, here is the link below for the Backbeat 903 ear tips (model 80846-01).
Plantronics BackBeat 903 Ear Tips
Good luck from Headsets Direct!
Nov 03, 2011 | Plantronics Backbeat 903 Bluetooth...
Cant hear an sound
I had a similar problem. Check these things
-Is it completely plugged it ? -is the Volume turned on ? -there is a slight possibility that the cable ripped from the inside , it happened to me , the cable inside the rubber snapped . to check if that's the case : pull on the cable on different places and if at one there is no resistance (feel like a elastic) then I'm afraid your ear phone broke and you need new ones
Sep 01, 2011 | Apple Earphones Headset
Instruction on how to wear plantronics 925 bluetooth
The round portion that has the smaller hole in the center, with the small extension, goes into your ear. The squarish loop then needs to be rotated to out, so that it is "hooked" into the curve of your ear. Try different sizes to get the right fit of the loop (the bodies are identical).
Jan 30, 2009 | Plantronics Discovery 925 Bluetooth...
Cracked green piece that holds earpiece on skullcandy headpones
Dec 19, 2008 | Skull Candy (NNTN5751) Headset
My son dropped his skullcandy headphones and cracked the green piece that holds the ear piece... anyway to replace that?
I dont think that they have replacement parts but they will give you 50% off you next pair if you warranty them.
Cut Skullcandy cord and confusing splicing process.
well i dont know how to repair them but you can get the warranty for 50% off another pair. does that help?
Dec 18, 2008 | Skull Candy KB Electronics Skullcandy (...
Broken Ear loop
I just called LG (800-243-0000) for the same problem and they said that they are sending me a new earhook and it should be here in 2-3 weeks. We'll see if I actually get it.
Aug 24, 2007 | LG HBM 730 Bluetooth Headset Wireless...
HS-23 Nokia Headset
hey kev.. all i can ask you is ... the following 1) open the ear piece of the non working .. then take a multimeter (keep meter in resistance mode) and check the resitance if its good it will show you.. apx 32 0hm and if its showing you 0 or .1 or below 16 ohms.. 2) after you disconnect the speaker.. the broken one that is... chek the cable connectivity.. or rather continuity.. for this keep the meter in continuity mode the pervious resistance mode.. then take one wire and connect one prob from meter to it.. and take the other prob and connect ti too the pins of the cnnector.. ( here is there are 4 pins dedicated to the ear phone.. 2 for each.. nd they are towards the end sid.. just below the # key.. frm # key the last 4 pins connectors are for audio.. ) check the.. pins on the cord connector not the phone.. i hope you can find what wrong with your... head set now.. and yeah if the speaker is out jsut replace both the ear piece with sony or aiwa earphones.. it wil work best if your cable is gone then all the best buy a new one tc aditya
Aug 04, 2007 | Nokia HS-23 Headset
Headsets Logo
94 people viewed this question
Top Skull Candy Headsets Experts
Carlos Jaen
Todd Zettlemoyer
Todd Zettlemoyer
Are you a Skull Candy Headset Expert? Answer questions, earn points and help others
