Problem with GE (PSS26MSRSS) Side by Side Refrigerator
My GE Model PSS25MGNAWW Artica Profile
1 Solution
My GE Model PSS25MGNAWW Artica Profile Refridgerator has begun freezing the contents of the bottom Sealed Pan and Fresh Produce Drawers. Put setting up to 2 and Chill Dial to Cold (left) but temp is stayng at 29-31 degrees. Where should I look?
793 people viewed this problem
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
1 Solution
  • 0ejeff
  • 1 solutions
  • Jan 25, 2011
Freezing in cripsersG.E artica:
Models Affected: All 23 25 27 and 29 cubic foot electronic side-by-side refrigerator units with plastic Liners manufactured in 2001 or later. This includes all Profile- (Arctica and Eterna") models Consumers have called with reports of freezing in the Vegetable (middle) pan or the CustomCool M (bottom) pan , frozen water tank or frozen water filter.Freezing in the pans , a frozen water tank or a frozen water filter is caused by excessive airflow from the vents in the tower.
To eliminate these freezing issues , install kit WR49X10045. Follow the instructions included in the kit.
Damper door broken G.E artica:
Affects all 2001 models produced with "M" as the eight letters in the model i.e.: PSS25SGM with serial date code LA4 , MA4 , RA4 , SA4 , TA4 , VA4 , ZA4 & AD4. Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
Replace damper door assy , with new damper door kit WR17X11508.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508.
Add your solution
Full Name
Top GE Refrigerators Experts
John Tripp
  • Solutions: 3420
  • Level: 3
  • Achievements: 5
Expert Badge
Are you a GE Refrigerator Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More (PSS26MSRSS) Side by Side Refrigerator Related Problems
Unsolved Problems:
See all GE (PSS26MSRSS) Side by Side Refrigerator Problems
Loading... Loading...
