Front Load Washing machine won't spin, drain or rinse
I have an electrolux Front load machine and it stopped working in the middle of the cylce. Water is in the machine, the drain, rinse and spinning buttons won't, all its does is make a strange noise. I turned it off and tried to open the door to let the water out but door won't open...any ideas on what I could do??? By the way, I live in Europe! Thanks, Megan
  • 2 more comments
  • Mleon Jan 18, 2008
    Thanks! I will try that :)
    Thanks so much for your help, its been 2 days already with the machine like this!
  • Anonymous Nov 26, 2008
    My 1 1/2 year old front loading Frigidaire Affinity was washing fine. With 17 minutes left, it just started making a strange noise (like when it rinses but not right). The clothes were soaking wet and had some water in the bottom. I stopped it and tried restarting it....still making the strange noise. I tried just spinning it.....still, just the strange noise. No matter what setting I put it on, it just makes that strange noise and does nothing.
  • Anonymous Mar 17, 2014
    Electrolux washing machine just stopped in the middle of the cycle everything turns on just makes a huming noise
    President:
  • 1,314 Answers
If you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Jan 18, 2008
    President:
  • 1,294 Answers
Click on Electrolux (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue you have your manual on line!!
  • 2 more comments
  • prem mathew Jan 18, 2008
    Take out your exit hose from behind the machine, try to drain at floor level. Be prepared for a lot of water. Then switch on the machine and press "end of cycle"; try the door after a lapse of 2 minutes.
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
    Boy! you're online; this is quite rare!! This is absolutel free service; you will rate me if helped.................. Do not force the door. If not helped click 'thanks for trying' you will be back for someone else to help..............................
    People hv waited 2 weeks.......am leaving the cafe now; bye God Bless you.
    tech17 is a great guy!
6ya staff
SOURCE:
Washing machine gets stuck each time on Rinse, Drain or Spin cylce and can't open door!
the drain pump cant get the water out of the machine check it and also check the filter maybe something stuck in it
Feb 10, 2014 | Tricity Bendix AW1000W Front Load Washer
Electrolux EWF 1495, Starts but dosent wash. Drum turns about twice then stops for a couple of minutes, turns then stops. It then indicates cycle ended but didnt rinse, spin or drain or spin. These can be...
OK, first remove the rear access panel. You will see a drain boot going from the tub to the pump. You will need to remove that boot and inside is a filter that you need to clean out. Reassemble and run a load and let me know what happens.
Dec 02, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Spisn cylce will not spin all the water out.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 23, 2011 | Maytag Neptune MAH5500B Front Load Washer
On HE3T wash stops in middle of cylce and flashes F2
"F02" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Most commonly, your drain pump has something clogged in it causing the drain flow to be obstructed. I would begin by checking the drain pump reservoir. I provided a follow-on link with the advice I gave you that explains how to do this. If you have any questions along the way, please let me know. I hope this helps you.
May 02, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Machine will not agitate for wash or rinse cylces
that could be your problem or your drain pump maybe full... try spin and drain see if it will drain
Sep 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore quietpak2 no longer rinse, drain, spin
Sounds like the pump, eighter blocked or needs new pump.Place outlet hose in to bucket to drain, if no water comes out its blocked, if water flows freely possible needs new pump.
Slim jim1
Nov 19, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
2,680 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
