Question about Saeco Magic De Luxe Espresso Machine
Heating element issue?
Just happened overnight, water seems to be unusually hot, when coffee is brewing, makes lots of steaming and gurgling noises and steam comes out from of the left side vent. When finished, sizzling sound. Had this machine over a year, this has never happened before. Tried the descaling process, didn't make a difference.
Hi sounds like a thermastat problem control needs professional tech to look at it cheers john
Posted on Jan 29, 2008
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Sep 21, 2014 | Mr. Coffee Coffee Makers & Espresso...
Vinegar solution cleans mr coffee modelJWX23 but can it be taken apart to clean it better the coffee doesn't come out real fast for long
No. This coffeemaker is not built to be serviceable in that regard.
You can wipe down the inner-sides of the reservoir for a slightly better maintenance cleaning. But, 4 cups of pure white vinegar (no water added) in the hour-long cleaning cycle followed by two pots of fresh water in the brewing cycle is really the best way to clean the rest of the inner-parts which contact the liquids.
If your real purpose for your question is how to resolve the elongated brewing times, I'm afraid that is a symptom of damage to the heating element. This too is not serviceable.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is one, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
You can get a faster brew cycle by putting warm water into the reservoir and making coffee right away. But, depending on your hot water supply, the coffee may not taste quite as good.
Jan 10, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
I push the start button (the one with the red light) and the light turns on, but then nothing happens. (Yes, I had water in the tank and coffee in the filter part.) Usually, I push the button, the light...
Sounds like there an issue with the heating element. When the element goes bad it wont pull any water from the tank nor will it heat the water sending it up through the shower head and onto the beans. Unfortunately, since Braun has discontinued ALL kitchen appliances here in the US many of the parts are obsolete including the heating element for this machine.
Mar 29, 2011 | Braun FlavorSelect KF 180 Coffee Maker
Our Mr. Coffee (model JWX27--it's less than 2 yrs old) stopped working out of the blue. The lights all seem to work, and the clock, but it doesn't start the brewing cycle. I've checked the timer/delay...
The heating element has gone bad. Since it is not a user-serviceable part, I recommend replacing the coffeemaker.
Mar 01, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Why does the coffee maker make a loud noise right before it brews the coffee?
Usually this is the expansion of steam as the heating element quickly rises to the preset temperature. This process heats the water to the correct temperature and causes the water to flow upward from the water reservoir. Then out the brewing spout over the coffee grounds.
It will usually make strange noises at the end of this cycle too.
The water is used up and remaining steam is vented.
Sounds more like a burping and last minute gurgle really. :)
Hope this helps!
Nov 17, 2009 | Keurig B100 Coffee Maker
Slow water drip
First of all it depends on the hardness of the water. Vinegar doesn't really work in the heavy lime belt area of the midwest. It is better if you use lime away. It is an ecolab product that is great at lime removal. Use one cup per pot. Then rinse two pots worth if this is the kind of machine that uses the same water that is put in during each brew cycle. Some brewers have a reservoir. Bunnomatic is an example of that kind of brewer. If you use lime away in that kind of brewer you need to run about thirty pots to remove all the lime scale remover from the brewer. Slow brewing can also be caused by over softened water. I drove from Indy to Iowa after installing a brewer and then a day later the store put in a softener and over softened the water causing the coffee filter to clog up with sodium. Also check the sprayer disc or head where the water comes out. Over time coffee "paste" will build up around the outlet and if you don't wipe it clean or "smear" the coffee grounds around the outlet that will slow down the brewing cycle. I have thirty years as a brewer technician and it is usually one of the things I have covered, providing that the heat element isn't defective.
Jul 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Saeco Magic De Luxe Espresso Machine Logo
132 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
