Question about Vtech 9009111 Cordless Phone
VTech 5.8 mhz won't work
All 3 handsets say "searching...." When I remove any one of them from the cradle the dispaly reads "place in charger." All handsets are basically dead.
  • 8 more comments
  • Anonymous Jan 23, 2008
    Strange, I too have the Vtech..all 3 phones don't work...display says charging, then switches to connecting?
  • DallasDazz Feb 09, 2008
    I also have the Vtech phones. Strangely, all 3 pyhone stopped working at the same time. I can't answer calls on any phone because they're all dead, although the base still records voice messages. The display on all three phones says "charging," and when I pick up a phone it switches back and forth from that to "connecting" or "searching for base" and "place in charger." How FRUSTRATING! I haven't had this phone set a year yet, and already its' useless. Is this normal? Is it the battery? Given what I paid for it, I didn't think I was purchasing a "cheap" phone. If it's garbage now, I'll toss it, but I'd like to know if the problem can be solved. Thanks
  • dhenry88 Feb 23, 2008
    Same issue. All phones are dead. While in the cradle, all phones display "Connecting...". When I remove the phone from the cradle the display reads, "Place in Cradle". This is very frustrating. Has anyone found a solution to this issue?
  • Anonymous Feb 25, 2008
    yea same problem
    a solution would be helpful
  • andyyosh Apr 18, 2008
    I'm having the same problem. Tried unplugging the base for a while and unplugging the rechargeable batter in the handset for a while but neither of these tactics worked. The answering machine works fine. Very frustrating.
  • Anonymous Aug 03, 2008
    I have had the same problem! I have read the "solution" and wonder if this has worked for anyone else? I have the phone off as we speak. If this doesn't work is there any kind of rebate from V tech since this seems to be a glitch in the phone system itself?
  • Anonymous Jan 13, 2009
    same here. and with me three stopped working at the same time. but i still have one that does work. Pain in the butts
  • Anonymous Mar 29, 2014
    bought a new handset and cannot pair it. the new handset is the same type as existing model vtech 2650 but just says searching.
  • GordonWayneWatts
    GordonWayneWatts May 17, 2014
    I think I know what's going on here, DallasDazz: VTech phones are unlike Panasonics insofar as Panasonics store their caller-ID on each phone itself, but VTech phones store Caller-Is at the base: I know that because I can't access the caller-Id when another handset is in use or when I'm away from the base. So, this strongly implies that the base (not the handsets) messed up: If the base is messed up (in your case), this would disable ALL THREE (3) of your handsets. -- Gordon Wayne Watts, LAKELAND, Fla., USA.
  • GordonWayneWatts
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Posted on Apr 18, 2008
  • 79 Answers
Register the handset(s) to the base by following the instructions in the user's manual under the "Registration and Operation" section.
If you have already registered the handsets, follow the below instructions to de-register. Once complete with the de-registration process, following the instructions in the user's manual to register the handset(s) under the "Registration and Operation" section.
Note: There are two different versions of this unit; please follow the appropriate set of instructions for your version/unit.
If you have a tone/pulse switch on the bottom of base, follow the VERSION 1 instructions: VERSION 1: DE-REGISTER ALL HANDSET(S) (with tone/pulse switch on bottom of base):
1. Unplug power from the base and remove spare battery pack.
2. Hold down [PAGE] while reconnecting power. When the POWER light begins to blink, release the [PAGE] key.
3. Hold down [PAGE] key for 5 seconds. When the LINE IN USE light begins to flash, release the [PAGE] key.
4. The HANDSET CHARGING light will blink 5 times. Within 5 seconds from when it stops blinking, press [PAGE] once.
If you do not have a tone/pulse switch on the bottom of the base, follow the VERSION 2 instructions:
VERSION 2: DE-REGISTER ALL HANDSET(S) (without tone/pulse switch on bottom of base):
1. Unplug power from the Base. Remove spare battery pack.
2. Hold down [PAGE] while reconnecting power. When the base display reads 'Pr', release [PAGE].
3. Press [MENU]. The display will read 'rh'.
4. Press [SELECT] to choose h1, h2, h3, h4 or AL (all).
5. Press [TIME/SET] to confirm.
6. Unplug power from the base, then reconnect power to complete de-registration.
REMINDER: After de-registering the handset(s), follow the instructions in the user's manual under the "Registration and Operation" section to register the handset(s) again.
Posted on Aug 24, 2008
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
Jan 21, 2016 | VTech Communications CS6114 - cordless...
How to activate a vtech phone
Instructions
    • 1Remove the battery cover from the back of the phone. Most models have a door that slides downward to reveal the battery compartment.
    • 2 Install the battery by inserting the connector on the battery wires over the pins in the handset battery compartment. The connector will only go on one way.
    • 3 Insert the battery pack into the compartment and replace the battery cover.
    • 4 Charge the phone by sitting it in the charger for a minimum of 16 hours on the first charge.
    • 5 Place the fully-charged phone onto the cradle of the base unit and wait for the display to show "PRESS FIND HNDST 4 SEC ON BASE." If the message does not come up, lift the phone off the base and put it back in the cradle.
    • 6 Press and hold the "FIND HANDSET" button on the base unit for approximately four seconds. The display on the phone will change to "PLEASE WAIT," then "HANDSET X REGISTERED."
    • 7 Test the phone by making a call.
Jul 14, 2014 | Vtech Lands Phones
How to conect the phone to the base?
Enter the model of your VTech phone into the search box here to download a copy of the manual.
Jan 10, 2013 | Lands Phones
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
How do i sync my vtech CS5111 to its base...please help...
have the main based plugged into a working ac outlet and active telephone line then place phone on base for 1 minute then remove base should sync within that time
Mar 18, 2010 | Vtech Lands Phones
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Cannot reregister phones to the base.
If your base is a VT2651:
1) take phone off of the base's cradle.
2) enter **335782 on the keypad
3) phone beeps
4) remove all batteries from handsets.
5) reinstall battery in 1st handset, and enter the code number for the base unit (sticker on bottom of base). First handset will be set to phone 1
6) repeat step 5 for all other handsets.
If your base is a VT2656, there is no keypad on the base. I don't know the trick to reregister the handsets. I wish I did, since that is the problem I am having.
Nov 22, 2008 | Vtech VT2600 Additional Handsetfor...
My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
May 16, 2008 | Vtech IA 5845 Dual Handset Cordless Phone...
Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Nov 06, 2007 | Vtech IP8100-2 Twin Cordless Phone
Vtech 9009111 Cordless Phone Logo
2,989 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
