I have a mitsubishi ws48511, it will not come on. Pressing the menu and device buttons gives me a code of 1 flash , pause , 2 flashes. It will repeat this five times. I have tried resetting it but will still not come on, Have also tried unplugging it and resetting it.
  • James Stramer Dec 30, 2008
    Hi i have this same problem excpt mine green light keeps flashing and not allowing me to do anything and i hear no clicking of a relay
  • 8,617 Answers
A code 12 means the set is not going into protection shut down. Can you hear any click of the relay when tou try to power it up?
Posted on Jan 18, 2008
My Mitsubishi ws a48 will not come on the timer lite blinks once then twice then goes off any help with this would be greatly appreciated i would also like to order a replacement remote for this tv it is a...
The flashes you've mentioned is a "12" error code which is no error has been detected by the processor.
Double check the error code by following the steps below.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the *** (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "24", the LED will flash two times, pause, and then flash four
times.
Let me know the result.
Jdvillanueva
Aug 04, 2011 | Televison & Video
Getting codes of 2 flashes then pause and then two more flashes. What does this mean
Error Code Operational Check
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occurred since the last Initialization
An error code of 22 indicates a shorted component or shorted power supply line.
Mar 01, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Green power light flashes 2 times pauses, flashes 2 more times, pauses, flashes 2 more times......for a total of 10 times.... then goes off and doesn't flash again until I press the "menu" and "device"...
Short protection--98% chance one of the two fuses that protect the convergence circuit is blown. Repair requires replace fuse AND CONVERGENCE OUTPUT CHIP/S I Have start to finish instructions for this repair (parts cost under 25 dollars) let me know if you want the instructions and we will get them to you. SD TECH
Sep 06, 2010 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WS-55857 turn on/auto turn off problem
After it shuts off, you need to get a code from the tv by pressing the menu and device buttons together for 5 sec. A code will flash at you made up of 2 digits. Example. 2 flashes a pause and 2 flashes points to a convergence failure. If this is not your code post yours and I will help you.
Jul 06, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Will not turn on...not the "green flashing light" issue, something different. it will turn on for 3 seconds, then turn off. I have already replaced the 7 capacitors and 2 fuse on the DM. any other...
Could be convergence. Check the error code by pressing menu and device together for 5 sec and the timer light will flash a code. If it flashes 2 times pause and 2 times again it is the convergence IC stk393-110 and 2 fuses. Goodluck.
Jun 28, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
I have what appears to be a 21 code
they dont have a 21 error they do have a 12 and a 22 error code. 12 means normal no error detecteced 22 is momentary upset after reset
Aug 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Shutdown
Mitsubishi's have an error code system (press both menu and input/device buttons on the front panel, the green light will flash a 2-digit code...(example one flash short pause two flashes=12 long pause then it will repeat four more times...error 12 is no problem found...the other codes are 21,22,23 and 24.........Good Luck.
Sep 26, 2007 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
