Question about Brother MFC 9700 All-In-One Laser Printer
Printer problems I have just replaced the drum and the toner in my printer and the left hand side of the printout is very blurry and unreadable? What can I do to fix this
  • migi Jan 18, 2008
    THIS DID NOT WORK ANY OTHER SUGGESTIONS??? THANKS
    MIGI
I have cannon LBP2900 .right side print out comes out all over margin level smedge and ink cant read why like this,
note: i am just change new toner and drum, but right side printout (margin level) all over length cant read . pls help me .
Posted on Jun 02, 2010
    Genius:
  • 1,003 Answers
PULL OUT TONER CARTRIDGE SHAKE SIDE TO SIDE AND REINSTALL
Posted on Jan 18, 2008
I have 3 to 4 months old canon Imagerunner 2420L Printer *** photostat without duplex or any network /scanning facility.The Printout coming very faded, if I print on the backside of the printout . Eve
hi my immage scanner ir2420 display says front left side is open /close but i close evry thing steel the same falts so may be power suply problem how can i get diyagram of power supply plz
Nov 05, 2012 | Office Equipment & Supplies
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
My printer is smudging the left hand side of the printout. How do I clean it?
Check and verify smudging not caused by toner cartridge by removing toner from printer and checking the blue roller. DO NOT TOUCH the roller as oil from fingers may cause image defects. If toner good suspect fuser causing smudging on your printouts. Note fuser not considered a customer replaceable part for this model.
Mar 11, 2010 | HP LaserJet 1320 Printer
My printer toner needs to be replaced. What do I need to replace? Drum or toner?
NO YOU DONT NEED TONER YET :()
the printer tells you it needs toner you dont .. take a piece of tape put it on the toner - i printer 200 more pages
see this video this will save you alot of MONEY
http://www.youtube.com/watch?v=hPCGZZIdXyM
Dec 29, 2009 | Brother HL-2040 Laser Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Printer Problem - Konica Minolta 7450
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal lines
A horizontal line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
Sep 03, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Brother MFC 9700 All-In-One Laser Printer Logo
149 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
