Question about Toshiba Satellite A135 Notebook
Stripped screw, memory door
Hi, I have a toshiba satellite A 135. The memory door screw is stripped and I can't open it to install the memory I just bought. Any ideas?? Thanks.
d. w.
  • dixie4 Jan 21, 2008
    Thanks for trying, the screw was too far gone. I ended up having to use a utility knife and carved the plastic around the screw just enough to open the memory bay. (Not the best solution). Since I was maxing out the memory, I figured I wouldn't be opening the bay up too many more times. Thankfully, the door didn't break, and it snapped back on satifactorily, so I didn't have to even buy a new door. I certainly wouldn't recommend this fix, but it was my only option. The Geek Squad at Best Buy didn't even want to take on this project. By the way, the laptop works great w/more memory!! Thanks again.
Geez, what a crab!
Posted on Jan 23, 2008
  • 38 Answers
To get a stripped screw out it must have force applied in the direction of travel. This can sometimes be accomplished by gently prying outward while turning. If there is no way to pry it try a dot of superglue on the end of the screwdriver, put it in the screw andwait for it to set up, then gently pull on the screwdriver while turning once a thread catches it should come right out. Remember to not re-use that screw.
Posted on Jan 18, 2008
  • Rob Robinson Jan 22, 2008
    Thank you for the lousy rating! I am sorry you did not find my sugestions helpful. I will no longer try to help people here. The next time you ask for free help thank the person that offers, they did not have to help you. The rating system here is ambiguos what "thanks for trying" really means is "you failed and offered a stupid solution but I am trying to be polite" "helpful" would have been appropriate. Try helping others here for awhile and see how thankless it can be. See my other posted solutions to see how stupid I really am. Not being able to help someone extract a screw, I should burn my degrees.
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
How do i change the ram in my Toshiba laptop. I
hi
this is kamal here to help u.
if u have screw driver so pls open ur laptop and change ur ram it's very simple and take risk...
best of luck
best regards
kamal singh
Oct 09, 2009 | Toshiba Satellite A135-S2386 Notebook
HOW DO I CHANGE CD/DVD DRIVE IN A TOSHIBA SATELLITE P105-S6114?
You can use the Toshiba Satellite guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
Sep 21, 2009 | Toshiba Satellite Pro A10 Notebook
How to open Toshiba R25 Series Keyboard
t isn't that bad... The top strip comes right off if you pull up per the M400 manual. Unscrew the two keyboard screws and pull the keyboard (slowly) toward the monitor to give you some slack in the ribbon cable. Then fold the keyboard back over the touchpad. Unscrew the two screws holding down the metal panel in the middle where the keyboard is (be careful - they were very tight for me and I stripped one of the screws).
Put in your DDR2 4200 memory and be off and away...
Aug 02, 2009 | Toshiba Satellite U305-S5097 Notebook
How to open back cover (to replace memory module)?
I had the same issue. And I found the problem elsewhere, I will give you what I know. The other ram stick is located under a cover that is under the keyboard. You have to pop off the bezel strip with all the media buttons above the keyboard. Then you remove the screws for the keyboard and it pops off. There you will see the silver memory module cover, remove the two screws to find the 2nd memory slot. After you remove the old memory, install the new. Put the computer back together in the reverse order. If you have direct questions, please forward them to rodolfo_ma@yahoo.com
Mar 23, 2009 | Toshiba Satellite M105-S3041Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Accessing memory (RAM) to upgrade
    First of all, remove the battery
    Insert a thin object under the securing strip and lift it up.
    Be careful, it may be very tight.
    Remove the securing strip.
    Carefully work with finger to disengage plastic latches securing the securing strip.
    Remove three screws and a metal brace securing the keyboard.
    Lift off the keyboard and place it on the palmrest
    Now you can access the memory modules.
    Jun 12, 2008 | Toshiba Satellite A25-S207 Notebook
    Toshiba Satellite A135 Notebook Logo
    87 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
