Question about Microsoft Xbox 360 Console
No display only sound
I once already had the 3 red light problem then i gave for an repair and it worked well for about a month and now when i switch on i can hear the sound of the console getting on but no picture even some time i get the 3 light again
  • mario  amalan
    mario amalan Jan 20, 2008
    hai man thanks for your advice but i just tried the towel method and it worked if it occurs once again i will send it for repair
    President:
  • 4,402 Answers
Error Codes XBOX360
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
send it it back to them for repair
Posted on Jan 18, 2008
  • Cary Farah
    Cary Farah Jan 21, 2008
    please mark the solution post as "fixya"
PANASONIC VIERA TX55as802b will not switch on red power/standby light blinking once every 3-4 seconds have been told its the screen and it cant be repaired can anyone confirm this or help.thanx
The manual says nothing about the power light flashing at that rate. Unless an expert tells you that's the specific indication for a failed screen, I wouldn't believe it. Most TV's will give you sound even if the display has failed.
Try resetting it by unplugging and waiting 60 seconds before plugging it back in.
If that doesn't work, most likely the power supply board needs to be replaced. Or possibly the T-con board.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 20, 2016 | Panasonic Televison & Video
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
PS3 shuts down playing game
this is called the Red Light Of Death it can be caused by the following
1.overheating
2. hardrive coruption or needs to be reset back into the system
3. the soldering on the motherboard of the console needs to be reflowed by a local repair shop that specialisez in PS3 gaming consoles
hope this gave you some information and good luck!
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 power supply switch off red light blinking on
its not the power supply. your cpu needs to be reflowed
May 31, 2010 | Sony PlayStation 3 40GB System
My xbox 360 has no display, i have bought a new cable but still no joy
ok if you still have sound but no picture then this means you should be expecting the dreaded red lights soon so take it to be repaired and it will be as good as new and i can assure you it isn't your lead that's the problem it shouldn't cost you much either to get it repaired but if there is no sound picture and red lights then its dead so just give up and buy a new one as this would be hard to recover and not worth anyone's time and effort as they seem to break a lot when they have already been repaired once before hope this has been of help
May 19, 2010 | Microsoft Xbox 360 Console
Red standby light is on (Goodman flat screen). When remote is pressd light light flickers as normal but t.v. does not come on. No picture. No sound. Screen does not even light up.
Kept trying to switch on, then mid-afternoon it worked. Had already phoned repair man and phoned back to cancel. He said that it may have been due to the extreme cold during the night and once the room warmed up it was O.K. Whatever, it is still working. Does that make sense ?
Jan 08, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
I tried to fix it on my own I need help ASAP
i think u might be getting the red ring of death my xbox did the same thing and a month later i got red ring
Feb 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 red light
James at joystiq fixed his own 360 that was flashing three red lights, which indicates an internal error.
If you have this problem try to fix it yourself before sending the unit in.
1) Remove your hard drive and/or memory units.
2) Run “Initial Setup” under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
It might save your xbox 360 a repair return.
Nov 06, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
