Question about Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5520 startup problem
My aspire just came up with a new problem after I just found a temp fix for the old one (had to completely disable the touch pad and use an external mouse because of jumpy cursor -- screens opening and shutting by themselves, etc.) Now upon startup, before any screens come up, the power goes on and off about 4-12 times before the laptop actually boots and the acer screen shows. This can't be good for the system. What to do?
  • 2 more comments
  • Anonymous Feb 14, 2008
    I had the same problem with my 5520 and I changed it, for some reason it started again and when I downloaded updated drivers via windows, I no longer get the icon of my touchpad and, thus, can't disable double-click which is driving me up the wall.. Keyboard has massive lag as well.
  • roygneo Apr 16, 2008
    my touch pad some times starts to touch itself repetently and i can stop it unless i shut down the computer and turn it on in a while!!!
  • Lancor Jun 02, 2008
    Touchpad tap is the problem, I found in the mouse options a check box that when unchecked disables the tap altogether. Cursor moves just fine, scroll at left and bottom of touchpad still works. You must then use the left button to select or double-click items. Note: this is not the one for disable tap while typing, it is on the very top section of the tap settings and is the first check box.
  • gwoods0617 Jun 21, 2008
    cursor jumps around too much....and scrolls down on itz own...its been jumping sice i have been typing this...this didnt happen when i had my dell note book.. how do i fix this problem?
Michelle-
I had the same problem with the cursor jumping around. My cousin bought the same computer and had the same problem! What she told me to do was go to the touchpad icon on the bottom right. Then click tapping and then check the box that says "tap off when typing."
It seems to have worked for us.
Posted on Jan 18, 2008
    New Friend:
Acer aspire 5520 touchpad programe problem
Posted on Dec 20, 2010
    New Friend:
Acer Aspire 5520-5537 same issue except now the unit powers on does POST and then shuts itself off. As you stated before though that it used to power on and off 4-12 times. The unit I have does that too, without the battery inserted. If I try to power it with the battery, it goes further does post and then dies. I think the issue is related to the cheap plug on the back of the unit comes unplugged frequently and has a loose connection causing damage to the power supply on the motherboard.
Posted on May 11, 2010
This mouse pad is atrocious! I have switched to a wireless mouse and turned off the tap click feature yet this still persists...I love the computer, but this is absolutely horrendous. I do not know what im going to do for the next three years because nothing seems to work
Posted on Mar 25, 2008
Go to control panel, select mouse, turn off taps and scroll settings,
slow down speed. Apply changes. It will cure most of the problems.
Ogg
Posted on Feb 15, 2008
    New Friend:
    Problem Solver:
  • 30 Answers
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 20, 2010
I too have the same proble i remved the alps touch pad driver which is installed by defaukt and the synaptice touchpad driver doesnt work . I am using an external mouse. I dont have any problem now. So dont use the alps driver it even slows the typing i mean when you type it displays to the screen a bit late than it has to . I hope this will help
Posted on Apr 22, 2008
6ya staff
SOURCE:
Mi webcam does not work
Does it maybe a updated software cause problem? How old is your notebook Acer Aspire 5520 ?You'd better descript your question more clear for detail,so that we can understand the real trouble of the Acer Aspire 5920 Notebook webcam.
Feb 09, 2011 | Acer Aspire 5520-5908 Notebook
I have the bluetooth software on my acer aspire 5520 but when i click on bluetooth settings it dosent come up with it.
Have you installed the drivers for it? does it have a bluetooth button/switch if so when you press it ,it should
come up on the screen in green writting "device enabled or disabled.
Nov 18, 2010 | Acer Aspire 5520-5908 Notebook
My acer aspire 5520 comes on then turns off how do I fix it
I've already solved my problem, and it maybe help somebody with the same trouble...so there you go:
1st step: Let the laptop turns on and off itself until it's screen turns to a white blank one
2nd step: Power off it
3rd step: Power on tha laptop. It will start normally and give you two options of startup
4th step: Choose to start the "recovery test", then it will repair any error and will start Windowsmag-glass_10x10.gif normally
Well, that's what I've done to recover my Acer...
Jan 19, 2010 | Acer Aspire 5520-5908 Notebook
My acer aspire 5520 laptop can't "find" my webcam.
Go to this link: http://gd.panam.acer.com/home/, choose notebook, aspire, and the 5520. Download the 3 camera drivers and install.
Aug 06, 2009 | Acer Aspire 4530-5889 Notebook PC
I have Acer Aspire 5520 But the Lan network drver on xp can not be found. So pls help me so that I can down load it. Thanks
Drivers for Acer 5520
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
From here select your required driver n Voila :-)
Lemme know if this solved your problem n if it did then please rate accordingly :-)
Feb 20, 2009 | Acer Aspire 5520-5908 Notebook
Wireless help!
try to open the show all networks window disable the default ethernet connectoin then enable the wireless net work
Jul 22, 2008 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520-5334
I had the same problem. It is due to the touch pad being to sensitive. My fix was to buy a usb mouse, and disable to trackpad by hitting the Fn key and F7. No problems anymore
Apr 02, 2008 | Acer Aspire 5520-5908 Notebook
How to get Service manual for 5520
I have the 5000 series service manuals, please email me at
[email protected] and I will send them to you.
Feb 09, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
2,410 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
