Message on display: JAMO CHECK PAPER. Paper checked, no visible jam. new toner cartridge. took the machine of power to have it reset. still same message. H E L P
  • 689 Answers
Usually that message appear if wheel stops before get its end point. You can move the wheels gently. Also be sure there is no blockage between wheels and sensor. Try to check mechanical parts briefly. Power Cycle (reset) the unit.
Good Luck
Posted on Jan 18, 2008
    Guru:
  • 1,894 Answers
Paper has been jammed
  • dewan nafees ahmed Jan 18, 2008
    no no.. remove the top cover and look for the edges.. the point till where the cadrige moves for printing..
    see if there is any paper stuck at tat corner.. you may have missed that corner point.. it wil be difficult to reach there.. but tat is the fault
6ya staff
SOURCE:
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Clear the paper jam message but there is no paper jam
Hi
To clear the paper jam check for any visible paper jams. If there are none then remove the toner cartridge and inspect for any bits of paper stuck under there. Hold the printer upside down and try and shake it gently to remove small bits of paper. Open the rear door of the printer and try to find any visible paper stuck. After this turn on the power to the printer. Hope this helps... Please post back if more help is required.
Daniel
Nov 08, 2010 | Dell 924 All-in-One InkJet Printer
Samsung SCX-4521F All-In-One Laser Printer states there is a document jam and toner empty but no documents are jammed and the toner has ink....cannot find the paper sensor to check if its causing the...
hello try to do this
press #1934 and right arrow key disply appear ready tech press menu &left arrow key display new cartridge press enter button twice. then toner empty message is over do previous simulation for go normal condition.
paper senser is located at back side of the machine remove backside cover and see heater unit near the hot roller paper senser is located
Aug 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
I cant recive any fax
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
Check drum cartridge
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
May 13, 2008 | OKIFAX 5650 Plain Paper LED Fax
Paper jam
try this
alternative :
May 04, 2008 | HP 610 Color Copier
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Open Questions:
Computers & Internet Logo
78 people viewed this question
Ekse
Marvin
Marvin
