Question about Sanyo PLC XU50 Multimedia Projector
Our projector shows a "disorted" video image (B&W instead of color, squiggly lines) and then shows the blue "no input detected" screen when in the VIDEO mode. It then powers down (flashing red lights) after about 2 minutes (NOT the "NO SIGNAL" countdown, it powers down on its own.
In the laptop/computer mode, it will display the computer image perfect, however it will also power down on its own after several minutes. Again, no warning, no countdown, just flashing lights until the fan stops blowing.
    Problem Solver:
  • 18 Answers
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
Posted on Jan 26, 2008
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Oct 01, 2014 | Dell 1210S Projector
I have a Sanyo projector that shows a completely blue image - I can see the computer image but it is completely blue - Whet I press the menu button the normal colours come up for the menu
it sounds like the wire you are using to connect your PC to projector is bad
if color is normal when menu comes up then it is not projector unless the input for your PC is bad
i would try new cable first since that would be cheapest
do other sources in other inputs work???
Mar 28, 2011 | Sanyo Office Equipment & Supplies
LCD projector not displaying color only black and white
Did you ever see color on this projector?
It could be the composite input cant detect the "color burst" 3.58 mhz signal for chroma.
Have you tried a different input?
That could help you track down what the problem may be.
Oct 31, 2009 | Televison & Video
My NEC mt1075 projector is projecting a shade of blue all over. The entire screen is showing the correct image, but also with a shade of blue. I think something is wrong with the internal wiring. Is this a...
If you're using component video (red/green/blue rca cables) one of the colors may be disconnected, or the wires may be swapped into the wrong color input. If you are using a 15 pin VGA connector, one of the pins may not be getting good contact at the source or at the projector. Or if the VGA cable is split into 5-wire to make a long cable run, one of the five wires may be disconnected. Any of these problems will cause a global color shift while not affecting the color of the projector's on screen menus.
Jun 22, 2009 | NEC MT1075 Multimedia Projector
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Pc connected vp6121 DLP projector shows only blue images
Feb 12, 2009 | HP Digital Projector Vp6110 Multimedia...
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Sanyo PLC XU50 Multimedia Projector Logo
328 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
