Question about Pentax ME Super 35mm SLR Camera
Film will not advance
My wife recently received a pentax me super from her father. He said that it worked the last time he used it (who knows when that was). I have replaced the batteries. The camera will not advance the film. The advance lever on the case can only be pushed half way, but it won't let you push the lever the full range to advance the film.
  • 4 more comments
  • Lithman Jan 19, 2008
    Yes, the lever has a slight resistance at the beginning of the stroke then none at all until it stops at a perpendicular angle to the back of the case. It does click into place when you push it back in flush with the back of the camera
    :D yes, I have a few precision screwdrivers.
  • balala3 Feb 18, 2008
    I have the same exact problem, where would they even fix such a thing?
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    remove the bottom plate, 3 screws I believe. There will be two loose pieces, both black plastic, an insulator for the motor drive contacts and the collar around the rewind button. Use the advance lever and try the film advance lever while looking at the bottom pieces, something may be out of place or jamming the works
  • Kevin Pettit
    Thats a good sign, the detent breaks off sometimes and jams the works. Do you have access to a small cross point screwdriver?
  • Kevin Pettit
    Does the film advance lever have any resistance at the beginning of the stroke? The lever usually has a detent spring that clicks when the lever is pushed flush with the back of the camera
    Scholar:
  • 85 Answers
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Posted on Apr 02, 2008
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
Pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
Dec 10, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Dec 08, 2009 | Pentax ME Super 35mm SLR Camera
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
Jun 08, 2009 | Pentax ME Super 35mm SLR Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
Loud grinding noise when I "****" the film.
kyle_walsh,
does this noise happen with film loaded or all the time?
this could be a broken gear or the take-up spool is slipping. with the film door opened advance the lever and check if the take up spool is turning. if not turning then a gear is broken. if the spool is turning then the spool is slipping.
there are no new parts available for the K1000, however some camera repair shops have good used parts that can be used.
the take-up spool was one of the very few weak parts of the K1000, you can make a temp. repair if you want.
on the take-up spool push down lightly on the gear like wheel and rotate the spool you should see a hairline crack under where the film is inserted. check both sides. if you find the crack put a very small amount of super glue on the crack using a tooth pick or similar tool. this works 80% of the time.
if you take or send your K1000 to a camera repair shop get an estimate first.
Feb 23, 2009 | Pentax K1000 35mm SLR Camera
Pentax ME shutter triggered just from advancing film
miraje,
the shutter locking lever is sticking. time for a clean, lube & adjust.
i would take, or send this fine rugged camera to a reputable camera repair shop, have an estimate for a cla.
This model pentax is made with very little plastic and will last a long time with an occasional cla.
Apr 02, 2008 | Pentax ME Super 35mm SLR Camera
Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Feb 18, 2008 | Pentax ME Super 35mm SLR Camera
Pentax Super ME
Yes, the ME super has an electronic shutter that works in conjunction with the LEDs. Purchase some fresh S76 button cells, A76 will work, but the will not last as long. Make sure the battery cover is corrosion free and install the batteries so both cells face positive toward the cover.
Jan 17, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
520 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
