Question about Refrigerators
Masterbilt mpm-48 my "she-beast", a masterbilt mpm-48, has started to shut its breaker off. the air filter is clean and there seems to be no overt or obvious reason for this disturbance. any suggestions on how to trouble-shoot a solution? i will entertain phone calls for help. i am annie at annie's bread&butter in oneonta ny.
  • 105 Answers
Hi Annie
it is possible that your masterbuilt is ok but your power system is failing.The circuit breaker may be too small to do the job and is failing.is there any other appliances connected to that circuit breaker
try turning off the c/breaker see what else is not going then isolate the appliances bit by bit
maybe you need to call your sparky the check the current draw on fridge and the rest of circuit
Posted on Jan 25, 2008
Fuel petcock? or ?
Check your choke adjustment. Sound to me like the choke is coming on. Loosen the choke adjustment and see if it still does it.
Apr 25, 2013 | 1999 Ducati Monster 600 - Dark - City -...
Dometic rooftop a/c compressor will not shut off. The only way to stop the compressor is to shut it off at the breaker. The fan and all other funtions operate properly from the thermostat. I tried...
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Oct 03, 2011 | Dometic 57915531 Air Conditioner
I have a 12,000 Amcorair mini split. Air handler shut down, popped the breaker. Turned the breaker on. The air handler displays F1 fault code.
Hello I think F1 fault is air filter...If it is clogged it can cause iceing (on the coil) and will trip a breaker.Give a good clean/wash or replace.
Jun 04, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
I have a Trane xr12 air conditioner. I turned off 230v breakers at the air handler, cleaned the filter and turned the breakers back on. now the compressor doesnt come on. I checked the relay on the...
Is the blower coming on inside? If it isn't, try tripping both breakers again. If the blower is working, your thermostat may be timed out or the air cond may have a timer in it that will keep it from coming on for a few minutes.
If none of the above work, make sure you didn't pull any wires off when you pulled the filters out.
May 28, 2011 | Heating & Cooling
EARLEIR TODAY I REPLACED ALL MY FILTERS FILTERS AND TURNED MY STA RITE E GLASS II ON ....IT RAN FOR ABOUT TEN MIN......... SHUT OFF AND NOW IT WONT TURN BACK ON HAVE RESET ALL BREAKERS IS THERE A RESET...
First to be sure shut the breaker off then turn back on. Most breakers require that you do this for safty reasons. Check all your power from the breaker to the back of the motor with a meter. If you have power shut it off then open the pump by removing the steel clamp that goes around the pump. Pull the motor and back half of the pump away from the rest of the pump. Now remove the difusser, the white plate covering the impeller. Then try to spin the impeller. If it spins then try to start thr motor. If it goes then you have a problem with the impellor or the difusser. If it won't start at this point you probally have a bad motor and will need to replace it. I always recomend new but you can get a rebuildt. If it's the impeller that will usually be obvious. You can take it into your local store and have them match the parts and they will usually do the bench work for just the charge for parts.
I hope this helps, good luck.
Aug 31, 2010 | Sta Rite Sta - Rite 2hp Max - E Pro...
Dirty smelly front loading washing machine
you need to find and clean the water return filter
Oct 11, 2009 | Washing Machines
2 problems
Make sure your air filters are clean and you are getting enough air flow. If you are operating it with the fan in automatic and it shuts off when the compressor cycles off change it to continuous circulation.
Fan on.
Jun 05, 2008 | Danby DPAC8020 Air Conditioner
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
