GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
Posted on Dec 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The machine seems locked on 1 hr..wont clear or
The machine seems locked on 1 hr..wont clear or allow any other features
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Dec 07, 2009
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409175
Points
5205
Unplug or turn off power . turn back try to program . if no luck / look for code on digital display . if no code replace the touch panel .. it has a stuck touch pad. ,, mm
tip
Reset 30 gig zune
if your zune locks up it is more than likely a bad music or sound file. the best way to unfreeze your 30 gig zune don't laugh it works by putting your zune in the freezer to clear memory and batery.
step1. put it in the freezer for 1 hr
step 2. remove from freezer and allow to come to room temp
step3. plug in and recharge fully
step 5. reload music on zune
How to program JVC vcr/dvd/tv remote 076D0FB010 for taping future tv shows. I can only tape shows live on my JVC HR-XVC1U machine.
It sounds like the remote you have, the JVC 076D0FB010, does not have the capability to program future recordings on your JVC HR-XVC1U or HR-XVC27U machines. This feature is typically called "timer recording" or "scheduled recording," and it is controlled by the VCR's built-in programming features, rather than by the remote.
You may want to check the user manual for your JVC HR-XVC1U and HR-XVC27U machines to see if there is a way to set timer recordings using the VCR's own controls. If the manual does not provide instructions for timer recording, it is likely that this feature is not available on your VCRs.
Alternatively, you can consider purchasing a universal remote that has the ability to program future recordings. Some popular universal remotes include the Logitech Harmony and the Philips Universal Remote Control.
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Microwave is locked up. Says Lock on screen and cannot get it to go away after hitting Clear several times. How do I get it off "lock" status?
HELLO.
GE manufactures various models of microwaves with a range of features.
Among them is a child safety feature that allows parents to lock the keypad. Though children can still open the door, the keypad lock prevents them from starting the microwave. The lock is in the form of a keypad code that renders the buttons inactive.
* 1 Press and hold the "Clear/Off" button on the microwave's keypad.
* 2 Hold the button down for three seconds.
* 3 Wait for the "L" on the keypad's display to disappear and display the time instead, signifying that the device is no longer locked.
Willing to help solve more problem.
Thanks.
1helpful
The lock function turned on for all files on my WS-100 and I can't get it turned off - therefore I can't record any new files or erase any old files. I've followed the directions in the manual but when I...
Try to reformat your device( do not use a PC.) instructions are in your operators manual...it will mean you will lose all recorded information but at the moment you cant use the machine anyway.
2helpful
Problem with child lock activated on bosch logixx 1400 washing machine cant seem 2 clear it - help!
Most, but not all have a manual opening device located somewhere near the strainer or any other access opening on the Machine.
Just for furture reference, if you press and hold the start button for five seconds the "feature" should disable... hope this helps
2answers
3000 traffic locked
You have to run the engine for 1 hr without trying to put the code in that will clear it after 1 hr you can put in the code
Clock resetting problems
You might contact your cable provider and see if their system indeed is broadcasting this subcarrier information. If so, is their system on the correct time? You might be able to turn this feature off on your VCR. Another thing to try, is disconnect the VCR from the cable system, set the clock, and see if it stays on time. This may indicate whether it is indeed locking it's time to the cable provided time.
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
