How are you trying to turn it on? It wont work with the PS button on your controller first time because to controller wont be connected via Bluetooth. There's a button (pressure sensitive not a push switch) on the front of the console by the BR disk slot. Its also possible it is switching on, does the green light come on at the front of the console come on? If so then you’ve probably not got it set to the right output channel. So it'll be outputting to your analog instead of your HDMI or vice versa. I think the Analog is standard so plug in a scart cable and see if you get something then change to HDMI in your settings.
Otherwise either your cable/tv or ps3 is broke :S
