Question about Solis Crema SL-70 Espresso Machine
Milk frother /steamer not working
Won't steam milk anymore. No water or steam comes out of hot water nozzle (steamer), just the main pump. Therefore I can still make coffee, just can't make a Latte, as the steam will only come out of the main pump, not the steamer. I've already tried unclogging the steamer, if that's the problem.
  • 3 more comments
  • wilmina Jan 21, 2008
    I can't remove the pipe as far as I can tell But I will try to decalcify again!
  • Karl Street
    Karl Street Dec 15, 2013
    I have similar issue - but I use bottled water and with not much calcium deposit. I have de-calcified every time requested by the machine. I guess I could try again to be sure
  • Anonymous Mar 13, 2014
    On my quickmill expresso machine when i turn the steamer on only a steady stewm of hot water comes out
  • Anonymous Mar 16, 2014
    Instead of milk coming out of frothier there is only steam when I press the cappuccino button
  • Anonymous Mar 26, 2014
    Its only been used 3 times , so not an age thing , it never has worked
  • 2,039 Answers
If you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Posted on Jan 19, 2008
  • pierre laplante Jan 21, 2008
    take anything push it in the pipe in and out unblock after you can decalcify if you dont remove the pipe cheers
    New Friend:
You have got it wrong its avax steam hard floor cleaner
trigerbroke you soposed to fix it you sent it back to currys
it still dose not work could we have our money back
Posted on Feb 03, 2014
THE FROTHER SPOUT KEEPS BLOWING OFF DURING THE FROTHING
I'm guessing this is a table top machine. If so then I take your meaning of "Blowing Off" as in turning off or running out of steam. The table top steamers usually found on home units do not have the capacity to froth large mugs like a "Venti" 20 oz cups. You will have to wait for the boiler to re-heat. It's best to heat a smaller cup of cold milk, pour the milk into the venti and make a 2nd batch again with cold milk. (It's hard to re-froth hot milk).
* check your steam wand tip if it's plugged with old milk. Soaking the wand in warm water overnite will help soften the milk which can be blow out when you make steam again. If you make a lot of milk drinks, it's a good idea to give the wand a blast of steam, then a good wipe with a damp cloth to keep milk residue off the wand.
* It's also possible your steam heater is starting to clog up. If you find that it gets slower and less steam with time then the steamer will need to be replaced. Check your warranty and call for service.
* Please update question with brand and model if you want more help.
Aloha, ukeboy57
Jan 29, 2018 | Coffee Makers & Espresso Machines
More detail to my question on mal function of milk frother. Coffee making function is working well and I have descaled as per instructions. When I try to use the steam arm there is a pumping sound but...
This might not be the problem , but sometimes , not cleaning milk frother tip properly , the tip gets closed with dry milk. use a needle and push it in the frother tip and see if there is a restriction. hope this helps.
Mar 22, 2015 | DeLonghi Pump Espresso Maker
Milk Steamer/Frother
Take off the end bit; it unscrews. Poke a needle through the hole; I find it gets blocked quite regularly. While it's disconnected turn the knob on the right. Steam should come out. If it doesn't there is a blockage inside the machine and you need to get inside it to fix it. But the only blockage I've had is in the end bit.
Jan 07, 2014 | FrancisFrancis! X5 Espresso Machine
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the...
try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Jan 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Apr 11, 2008 | Coffee Makers & Espresso Machines
Solis Crema SL-70 Espresso Machine Logo
1,424 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
