Question about Sony Cyber-shot DSC-W50 Digital Camera
Flash not present
When i am taking picture a flash is not come while the flash in on condition also...
    Scholar:
  • 173 Answers
My flash on my minolta had an auto flash and would flash in lowlight ...it had a mind of its own, you might want to switch to manual flash in your menu. if that isnt help some pop-up flash engage a switch... make sure its all the way popped up.
then bulb itself might be out look for black spots inside the flash.
Posted on Jan 18, 2008
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
How do i turn the flash off
Welcome to FixYa.
The FORCED OFF mode is the setting where flash is not activated in any recording condition. this mode used when taking pictures in places where the use of the flash is not permitted.
There are other 5 different mode/setting in using photo flash.
1. AUTO - flash automatically activated according to the recording condition.
2. AUTO/Red-eye reduction - flash is automatically activated according to the recording condition. It reduces the red-eye phenomenon by triggering the flash before actually recording the picture. After that, the flash is activated for actual recording again.
3. FORCED ON - use the when your subject is back-lit or under fluorescent light.
4. FORCED ON/Red-eye reduction - use this when you set the camera to PARTY MODE
5. Slow sync./Red-eye reduction - use this when you take pictures of people in front of a dark background.
I hope this solution will help you. Just send us you comments or suggestion if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
I have a cannon powershot a720is and will not take pictures in low light conditions, when i press the button to take picture the orange light comes on, but it does not take picture. When in a bright light...
This sounds like a flash issue.
From page 64 of the user manual, make sure that you have the flash enabled on the camera. Page 64 shows you how to enable and disable the flash. Most likely, the flash was turned-off by mistake and is causing your issue.
If the flash is enabled and you're still having a problem, then there's a good chance that the flash feature has failed on your camera and will need to be repaired.
Dec 29, 2010 | Canon PowerShot A720 IS Digital Camera
I have sx100 camera. when i am using to take a picture with flash i cannot take the next picture immediately. some times it take more than 30 sec. without flash no prob. this is not a memory card problem.
It depends on your battery condition, flash capacitor will charge faster if battery is freshly recharged. Or battery has larger current capacity. You can shoot pictures with flash faster if its fill-in or closer in distance. Which means capacitor recharge is not totally depleted for each flash duration.
Aug 26, 2010 | Canon Cameras
Flash
checking on the first 2 comments, if there is flash and the pictures are dark - please check the lighting conditions
is it a dark place, fairly lighted or fully lighted
the flash also has a certain range, the subject may be far that the flash cannot reach it
if there is really no flash - it may be a hardware problem, pls contact kodak to arrange repairs
try going to PASM> fill flash too, if still not working - repairs =)
Nov 11, 2007 | Kodak EasyShare C875 Digital Camera
Flash Problem
there is no chance you can fix it.. you need prof service to fix it. internal flash circuitry malfunction is present. try shooting in program mode or manual setting ( not using flash).
Jun 05, 2007 | Olympus Stylus 710 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
