Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
110.23812100 washer Unit will work fine however during the spin cycle it will not come up to speed. Appears to spin heavy lads better than light loads . Could this be the coupler or teh clutch?
  • 3 more comments
  • jzbo Jan 18, 2008
    Unfortuantly I have to agree with the Gear box problem.
    I have taken the motor off to get to the coupler and yes it is a bit worn but appearsto be in tact and not causing the problem.
    As of now I am trying to get the agitator out of the drum in a attempt to remove the gearbox/transmission.
    Any step by step directions you can give I will gladly take..LOl
  • jzbo Jan 18, 2008
    Have the gearbox out now.
    It enguages in one direction and spins freeley in the other.
    Is this normanl?
    I would think it would enguage in both directions,
  • jzbo Jan 18, 2008
  • jzbo Jan 18, 2008
    with or with out the gear box installed.
    With it it spins by hand but is stiff. no hang ups or dead spots. with out the gear box, yes it spins no noises or such.
    I have taken the gear box appart..No signs of extra ware on the plastic gears. Actually they all look really good.
    When it spins in one direction it enguages the aggatitate mode ( I assume) becauuse you can see it connect to the swing gear
    The other direction it spins freely.
    I am sure every thing is back together correctly .
    I am going to put it all back together and see what happens.
  • MyRepair May 11, 2010
    he part # given for the repair manual did not come up. Was this a manual for the Maytag Brovo washer mtw6600tq0?
  • 5,911 Answers
I hate to say it, but more than likely this is a sign that your gearcase (transmission) is starting to go bad. When they wear out, they tend to exhibit slow spin problems. I have seldom experienced a bad clutch causing this. When the clutch goes bad it tends to cause the drum to not want to stop AFTER the spin cycle. In addition, if the motor coupling were bad it wouldn't spin at all. If you purchased the washer recently, it may still be covered under the manufacturer's warranty. Some manufacturers will cover the transmission beyond the usual one-year limited warranty. It's usually covered for 5 years, I believe. You may want to double check your warranty to be sure. Now...if it IS the transmission, and it's NOT covered under a warranty, all is not lost. A new gearcase runs about $145 and the part number is 423. It is also recommended that you replace the motor coupling at the same time. The price is about $14 and the part number is 1195967. Most consumers feel intimidated by the thought of replacing a transmission in a washer, but on this model, it is fairly simple and straight forward. I can provide you with step-by-step instructions, or if you like, you can purchase a do-it-yourself manual for about $17 (part# 1170635). Think about it...about $170 to repair your washer yourself. Or...spend over $300 to have the appliance repair guy do it for you. $170 is still cheaper than buying a new washer. I hope this information is helpful to you. Post back with any comments or questions you may have.
Posted on Jan 18, 2008
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Jan 18, 2008
    If you haven't done so already, the agitator comes out fairly easy by removing the cap and bolt underneath. The whole agitator should pull off the transmission shaft. There is a small plastic piece that sits on top of the spanner nut, along with a clip that fits around the transmission shaft that have to be removed. Once all of this is removed, the transmission will slide out from the bottom of the washer by loosening the three bolts that hold it in place. You will have to lean the entire washer back to allow room for this, though. It's that simple. You do not have to remove the spanner nut or the tub. The brake assembly sits atop the gearcase and (if you don't want to replace it) it will have to be removed and retained for the new gearcase. There is a cup hook shaped retaining clip that comes out with a screwdriver and a metal washer that you need to hold on to as well. Slide the brake assembly off the shaft and the gearcase is completely removed. If you purchase a new gearcase it should be shipped to you in the UPRIGHT position. The gearcase contains oil and must stay upright at all times. Just prior to installing it is important to poke a small hole in the breather hole on top of the new gearcase with an awl. There should be a warning label explaining this. Just remember how you take things apart and place all parts in one location as you remove them. This will make the process of reassembly much easier. I hope this helps you. Let me know if you need further advice.
  • Jeff Rockwell
    You know...I can't remember. I think it depends on what gear is selected. Were there any indications of oil leaking from it?
  • Jeff Rockwell
    Okay...just thought I would ask. This is sometimes a dead give away that you have a transmission problem. However, it doesn't always occur when a transmission goes bad. From what I remember, the transmission shaft would spin free, but I can't remember if it would spin free in one direction, or in both directions. I would turn the shaft to see if I could feel any gears scraping or dragging. There's not much inside the gearcase except for a couple of spindles, an actuator arm, and oil. When the gears wear down they can start to slip. It was just much easier to replace the entire gearcase rather than attempting any repairs. Does the tub spin freely?
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My top load Bravos washing machine wobbles during spin cycle.
Most likely suspension rods and bushings need replacing. Also check outer tub ring. Sometimes it will break from beating on sides of washer, behind where water comes out.
Sep 30, 2017 | Maytag Bravos MTW6600T Top Load Washer
Washer Spin Cycle doesn't work - sometimes
Hello T Wright - Based on the symptoms you are describing, it sounds like more than likely the unit is sensing an out of balance load, which could be too light or to heavy of a load, and the unit will not advance to high speed spin. However, often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 13, 2013 | Frigidaire GLTF2940ES Front Load Washer
My duet ht front loading whirlpool washer goes through a complete cycle then during the spin and drain ( the last cycle) it displays a f6 notice and will not complete the cycle, you cant get the wet...
Thanks for using FixYa. Error F06 in your washer indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Aug 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not spin, during rinse & I'm assuming spin cycle
throw pin in trash..shipping pin..spin problem..if motr runs and unit agitates suspect transmission or clutch on top of transmission
Nov 27, 2008 | Roper RAX4233PQ Top Load Washer
Clothes too wet upon cycle completion...
Try reducing the amount of low sudsing detergent you are using. This can make the load too heavy and won't spin out. Remember suds have 3 parts, air, detergent, and water. The drain pump is designed for water, so if you see suds during the wash, it will be worst on warm and hot, then there is too much detergent, or is not low sudsing. I know Bosch reccommends HE, however HE liquids normally are not low sudsing, just High Engery. Also the Permanent Press cycles are always a lower spin speed. Hope this helps
Jan 20, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Kenmore 110.92195110
those parts come as a complete kit. order a brake assembly.
Jan 06, 2008 | Kenmore 22422 Top Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
1,065 people viewed this question
Sal De
 Brian Main
Brian Main
