Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony tv kv-29F1U
Flashing tv signal every five to ten seconds
  • Anonymous Jun 14, 2008
    when the on button pushed it keeps flashing red, picture came on then went of after a few minutes could you pls tell me the problem do not have the remote.
    Scholar:
  • 173 Answers
Tuner needs replaced or taken apart and cross your fingers soldering joints, use silver solder look hard with magifiers for solder cracks or bad joints and grounds inside tuner.
Posted on Jan 18, 2008
Sony Wega KV-30HS420 input problem
Just reset the TV to its factory settings and check. To do this you have to enter its service mode option. How to enter the service mode option is described in one among the posts at the site linked here.
But, before doing this reset, just connect the HDMI cable to the TV, and input an HDMI signal to it. If there is no input signal, the set will display as 'no input'. Check this first. If you wish to get further assistance from me, come over by FiXya comment.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
My sony trinitron kv 40xbr 700 flashes five times is this something that i can repair or do i need to seek a professional and how much (ball park figure) will it cost?
Probably just a bad lamp. Look up the LED status codes for your particular model. Five flashes will indicate a particular problem, and usually it's the bulb.
Jun 08, 2010 | Sony KV-40XBR700 40" TV
My sony trinitro wont turn on, the stand by light flashes 4 times
the four flash is a signal, it means either faulty power supply or deflection circuit trouble.
Jul 27, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony Trinitron KV-32FS12
    i think your tv had a lose contact or crack on board
    Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony kv-36fs320
    When a Sony TV flashes five times, that means that there is an AKB circuit fault.
    This means that there is something wrong with the video.
    Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
    Sep 21, 2008 | Sony FD Trinitron WEGA KV-36FS320 36" TV
    Flashing Screen
    ok, the problem you may be having is bad solder connections on the vertical deflection IC. resolder them or have a tech do it. also check for bad solder on the 9 volt regulater IC as well. these problems are common to older sony sets.
    Feb 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
    129 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
