Question about Mercury KVM266PM-U (KVM266PMUD1600) Motherboard
Hallo on turning on my PC it brings several options for starting windows e.g. start normally, safe mode, command prompt etc. when i select any of the options the pc restarts and keeps on restarting
  • assesswp Feb 28, 2008
    yes I have identical problems with my system, can u help
    Genius:
  • 1,601 Answers
  • Thomas Christopher
    Thomas Christopher Jan 24, 2008
    did this work for you? If so please rerate as FIXYA. Thanks
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2013 | Computers & Internet
I had to launch start up repair and the battery died half way through... The laptop now says "Computer build error. File exception failed to find c:/ (etc)" and it won't turn on, just...
Step 1:
Enable VGA mode
Reboot
Feb 07, 2013 | Computers & Internet
Hi I have a fujitsu amilo pi 1536 laptop and wish to return it back to factory settings. All i have is the laptop and no recovery disks etc. I've tried pressing F8 which brings up the windows advanced...
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
Aug 02, 2011 | Fujitsu AMILO PC Laptops
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
My ASus eee pc is in a constant loop. It starts up with start windows in safe mode safe mode with command prompt or start windows normally... After I select start windows normally it's in a loop and starts...
Ok-Go to Safe Mode-any-click on start menu-run:msconfig-hit enter-click on restore option-choose date-go! If you can't do that, on boot you machine should tell you what other option you have-like"push ESC button to aces setup" or something like that. Hit that button and go to RESTORE function.Good luck and Happy Holidays!
Dec 27, 2010 | ASUS Eee PC 901 XP Notebook
How run in safe mode with windows vista
When you turn on your computer, press F8 and that will give you some start up options, the first ones being Safe Mode, Safe Mode with Command Prompt and Safe Mode with Network.
Nov 01, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Unable to start window.
  • select to safe mode
  • goto start - programs - accessories - system tools - system restore
Jun 03, 2009 | Acer Computers & Internet
Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Logo
59 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
