Question about Cnet CWR-854 Router
CWR-854 router Can you help me please to connect to internet with CWR-854 Router? I have Notebook Toshiba and from my provider a grid antenna with coaxial cable. I connect antenna to the right side near power switch, and LAN 10/100 from Router RJ-45 to RJ-45 of the Notebook. My IP are 192.168.16.2 from ISP. Connection between Notebook and Router is done. i can give default IP of router 192.168.1.254. When I go to the Internet explorer to made a configuration of Router there I don't know which IP to give the same or different IP of LAN? best regards [email protected]
    Problem Solver:
  • 5 Answers
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Posted on Jan 25, 2008
6ya staff
SOURCE:
I cant install my cnet wireless g router cwr-854
you should contact your internet provider for professional advice. it's most likely free and faster than asking nerds on the internet who doesn't know anything about your specific router-model ;)
cheers
Mar 17, 2011 | Cnet (CWR-854) Wireless Router (cwr854)
What is it used for?
You can use this wireless router to connect different wireless devices together. Each device with a wireless network card (computer, phone, gaming system, printer, etc.) can connect to the router without a cable. This will form a network where information can be shared.
The main purpose people use this for is to connect their network to the internet. As long as the router is connected to your internet, every other wireless device can also connect.
Thanks,
Pat
May 24, 2010 | Cnet CWR-854 Router
Cannot connect to internet, already configure my wireless CWR-854, thru 192.168.1.254, when im in internet, my deafault gateway is 192.168.1.1, please help
online user manual is here http://www.cnet.com.tw/download/cwr-854.htm If you goto page 37 it show the dhcp range . Make sure your pc cofiguration is set to dhcp - automatically obtain and IP and DNS - this is explained on page 10/11 try this Start>run{vista/7 search box}>cmd>ipconfig /release Start>run{vista/7 search box}>cmd>ipconfig /renew see if that produces the correct info
Mar 20, 2010 | Cnet CWR-854 Router
How to use my Cnet CWR-854 Router as a wirerless antenna for pc.
You can't really use a router to connect to another router, you can sometimes use them as an "Extender" for range, but not as a WiFi card, they simply aren't made to operate that way.
Feb 19, 2010 | Computers & Internet
I dont know how to access setup wizard for cwr-854 cnet router
To access Router type that --> http://192.168.1.254 into your browsers address bar, a password & logon box should appear, The USERNAME is root The PASSWORD is 1234
Now you should be able to access wizard.
Here is a better manual.http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20Quick%20Install%20Guide.pdf
Feb 09, 2010 | Computers & Internet
Trying to access 192.168.1.254 for siemens se567, followed advice to go to run and cmd ping, don't understand other go to access point, my situation is the older couple I live with have wirless internet in...
The internet connection has a security that's why you can't access the internet. The only thing you have to do is to know the wpa password of the router.
This router has a default username and password to configure all the settings. This is the manual for Cnet CWR-854 Router:
http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20User%20Guide.pdf
It seems that the router is already configured by an authorized person, the best thing you should do is contact the authorized person that knows everything about the router.
Jan 25, 2010 | Cnet CWR-854 Router
Is there a conflict between linksys BEFW11S4 router and CWR-854 cnet router?
No problem at all. The router can function as bridge with no conflicts with other routers.
Nov 10, 2008 | Cnet CWR-854 Router
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Apr 24, 2008 | Cnet (CWR-854) Wireless Router (cwr854)
Setting up a wireless network with internet
You will need to logon the router via the computer, and create a PPPOE internet connection. If you cannot connect to the router wirelessly my may need to use a cat5 cable between the computer and the router. The user manual that came with the router will show you how to do this. If you do not have the manual. Do the following: open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway".once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank.once logged on the router go to internet connections and select PPPOE enter the username and password provided by your ISP save the settings and you should make the internet connection now. BPCS
Dec 26, 2007 | Cnet CWR-854 Router
Cnet CWR-854 Router Logo
163 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Jim LeVerso - IT...
Jim LeVerso - IT...
Keith Koene
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
