Question about Freezers
Hotpoint FFS70 freezer door won't close
Recenly the freezer door has become more difficult to close - I have checked that the drawers are pushed flush against the back of the freezer and that there is no ice build up blocking them but they still seem to be sticking out too far forward. Today I have taken the drawers out and just stacked the food in there and the door has closed ok. Can you help please ?
  • JKBUK Jan 27, 2008
    Thanks for your help - I found the problem though.....I didn't realise that you could take the back panel behind the drawers off. Once I did this, I found a build up of ice which had pushed the back panel forward and this was the reason the drawers and door were not closing. I defrosted it and screwed the back panel back on and all is fine now.......
  • charchies Oct 20, 2008
    Is the panel easy to get off?
    and why does this happen?
I have the same problem, is the panel easy to undo?
Posted on Oct 20, 2008
    Problem Solver:
  • 11 Answers
There must be a basket that is bent ,
Posted on Jan 25, 2008
  • Bob Bonds
    Bob Bonds Jan 27, 2008
    Exellent!!!
The door on the freezer will not keep closed. What could be the problem?
There must be something your not seeing, get an extra set of eyes on it.
Oct 25, 2015 | Frigidaire LFFH17F7HW 16.6 Cubic Feet...
WATER FILTER WILL NOT ENGAGE
Hi friend, I appreciate your post!
I see your question is labeled under Frigidaire refrigerator, FGHB2844LF, and you are having difficulty engaging the water filter. Based off that model you should be able to push on the face of the water filter and slide the old cartridge out. First, to install the new cartridge you would need to remove the caps off of it. Secondly, using the alignment guide slide the new filter into the housing until it stops against the snap-in connector. Thirdly, push firmly until you hear the click which indicates that your filter has been engaged. Lastly press a glass against the water dispenser to verify no leaks are present at the filter housing. Hope this helps. -Matt
Aug 02, 2014 | Frigidaire Gallery FGHB2844LF 27.8 cu. ft....
Door was not shut tight. A loud buzzing sound recently went off and only stops when we unplug or turn off freezer. :(
loud buzzing I believe is an alarm that is waring you that the freezer is not cold enough. Door problems can be fixed. Test is to stick a dollar bill in the door and shut it. It should be a little hard to pull the bill out. Do this all over the door and find all the bad places. One problem is that the door can become warped by banging it against something or kids hanging on it etc. If you can see the warp you can actually bend the door back into place by holding the bottom of the door and moving the top in the necessary direction. Like jamming your foot against the bottom and pulling on the top or putting a box at the bottom of the door to hold it open and push the top. Next many time the bad fit door is because a hing has moved. All the hinges are adjustable. Usually you loosen the screws and move the door in the appropriate direction and re-tighten the screws. These screws are very tight so you need a big screwdriver and someone big to turn it. Lastly you can purchas a completely new door seal and put it in..
Sep 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Freezers Logo
188 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
