Question about Audiovox AVP7000 VCR
This is an easy one for you
How you doin'? This is an easy one for ya, I'll bet. Whenever I eject a tape, it catches on something and I have to open the cover to retrieve the tape. I cannot see anything suspicious happening in the hardware but I know it must be something very simple like a spring losing its spring(!!??) I bet you'll know what to do though. So, if you solve this annoying little quirk, I guarantee I will boost your solve rate right up there with the best of em as I have queries that need solving and gadgets that need fixing
    Scholar:
  • 57 Answers
I am looking forward to my boosted rating from you!
Solution: The tape not spooling back into the cassette is caused by a fault with the idler or clutch mechanisms. There are usually felt clutches associated with the idler gear and felt clutches on the take up and supply reels. On many VCR's the idler gear engages a direct drive gear for FF & FR, whereas for cue & review the idler gear engages a gear that drives the spool via a felt clutch, the same gear that is used for play. During play, however, the capstan/pinch roller pulls the tape through the mechanism with the take up reel pulling in the slack tape. Check for a slipping felt clutch mechanism. A little trick that works well, remove the offending spool and most spools can be popped apart, use some violin bow resin and carefully work the resin into the felt. You will find that the resin restores the lost grip of the felt with lasting results. Violin resin can also be dissolved into alcohol to provide a gloss finish over reworked solder joints.
Posted on Jan 18, 2008
    Scholar:
  • 167 Answers
Hello. it's sound's like that the idler cam wheel that turn's the tape has a problem. it could be that .the wheel if made of rubber is slipping. or it has a belt on the bottem of it that is ***** out. check those two thing's .and let mre know if it has a rubber wheel .? or teeath that turn a gear. and if the belt on the bottem of it is not tight on the two wheel's on the bottem of it. let me know.ok "good luck"
Posted on Jul 03, 2008
  • MICHAEL WALLACE
    MICHAEL WALLACE Jul 03, 2008
    hello. it's sound's like that the idler cam wheel that turn's the tape has a problem. it could be that .the wheel if made of rubber is slipping. or it has a belt on the bottem of it that is ***** out. check those two thing's .and let mre know if it has a rubber wheel .? or teeath that turn a gear. and if the belt on the bottem of it is not tight on the two wheel's on the bottem of it. let me know.ok "good luck"
  • 2,130 Answers
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
How do I get a VHS tape out of a Go Video DVD/DCR combo?
you will have to open it up to get it out as the tape might be stuck around the play heads
Oct 23, 2017 | Televison & Video
Shuts off when eject button hit.
does it open when you when you connect it direct to the wall scoket.
Jun 04, 2008 | Quasar VM-L153 VHS-C Camcorder
Can not eject video cassette from RCA VCR model VR680HF
Best thing to do here is open unit and have a look--likely the tape is bound up on a post or something--usual cause is the mechanism that rewinds/plays the tape is not working right----when eject is hit it rewinds and puts the tape back into the cassette.
This unit is old enough to have about 5 belts and a rubber drive wheel any of which if broken or bad will do this.
They used to sell a belt pack by model number with the drive idler--pretty easy to replace IF you can find the parts.
SD TECH
Apr 26, 2012 | RCA Televison & Video
Cd in macbook wont ejec
This can be a problem. First try rebooting the machine, and holding the eject button when you hear the startup tone. Hopefully, that will force-eject it.
If that doesn't work, you'll need to get creative. Get a playing card or something similar, and put some rolled-over tape on one side close to the edge, so there's a sticky side out. Turn the computer off, and try to get the playing card into the CD drive, with the tape making contact with the stuck CD. Reboot, holding the eject button when you hear the eject button again, and pulling the card out. Hopefully, the CD will come out with the card. If it doesn't work, just keep trying, and you'll get it out eventually.
Generally what causes this is keeping CDs in the computer for an extended period of time, especially while the computer is powered off. Make sure you remove all CDs before moving or turning off your computer.
Sep 07, 2011 | Apple MacBook Laptop Computer Mac...
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
Tapes won't play and won't retract when ejecting
This is the most common VCR problem of all time. The piece call the idler tire is worn down and needs replacing. This is the little wheel in the mechanism between the 2 reels that flips back and forth depending on which direction you've told it to go. It has a rubber tire around it to allow some slippage so that the take up reel can go whatever speed it needs to as it accumulates more and more tape on it as it goes through your movie. Sometimes this tire is very difficult to get at so it isn't something you should try to do yourself unless very mechanicly inclined. Replace the rest of the rubber belts while you're at it.
Hope Ya Fix it!
Jan 04, 2008 | RCA VR349 VHS VCR
Tape door will not move; stuck in open position
there should be a 800 number to call 1-800-555-1212 as the operator for a the number support JVC. you can go to there site www.jvc.com (i think)there you can find a local support repair shop. you can a chance open look inside real hard to see if something pop out of place in it. i know it stick a lot, me and my aunt have both JVC Camcorders my is a older model her's is a newer one. i would seek out a support center who work on them, seek out JVC and see if there a local repair center in your area
Jun 27, 2007 | JVC GR-D270US Mini DV Digital Camcorder
Audiovox AVP7000 VCR Logo
152 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
