RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Dec 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please help with my rca 52 projection TV power issues
  • 3 more comments
  • rondis18 Dec 11, 2009
    I don't know the fix that's the issue. It is a constant flash of this same code every time I hold the button. 1 flash a pause followed by 9 flashes.
  • Anonymous May 11, 2010
    i disconected power for 30 minutes.. now the power lite will not come when pushed. earlier done,,,cp150, cp120,cp112, replaced, resolded .00087uf-2000v cp near cl031, solder was blow out.. code now is 9 flashes pause 1 flashes any suggestion??
    """Can you describe what happens when you press power? I need to know what the power light does and also if you hear any sounds."""NO SOUNDS << power button when pushed..the led flashes code "95", flashes 9times pause then 5times. restarts cycle. obiviuosly this is a codes of some sort. please explain cause with a possible fix
    the led flashes code 95, flashes 9times pause then 5times. restarts cycle. obiviuosly this is a codes of some sort. please explain cause with a possible fix
Sonny Berry
Level 3:
  • RCA Master 8,617 Answers
  • Posted on Dec 07, 2009
Sonny Berry
RCA Master
Level 3:
Answers
8617
Questions
Helped
1721723
Points
23750
Can you describe what happens when you press power? I need to know what the power light does and also if you hear any sounds. Respond to this post and I will assist you with whats happening with your set.
1helpful
Power issues. plug the tv and the power light keeps blinking. no reset button found. please help.
The blinking is the the the error code that will tell you what is wrong with your TV. You will need to count out the number of blinks. Then repost a new Question with the number of blinks! I hope this will help you get on the right track to fixing your TV!
9helpful
My 52rear projection tv flashes3 times but wont
www.tvrepairworld.com has a RCA repair kit called CP150, CP120 and CP114 capacitor repair kit which should repair that issue. The kit also contains the CD with instructions.
POWERS OFF
CP150, CP114 and CP120 Capacitor repair kit at www.tvrepairworld.com should repair that issue. The kit contains the parts and the CD with instructions.
Thomson tv projection "52" light blinking.
It apears you have a low voltage problem. This is not an in home repair and may be time to consider purchase of new model. Hope this helps good luck
Rca 52 in rear projection not staying on
2 things,
1....capacitors in a power supply 2200 25V, 220 35V (2) and 1000 25V.( upgrade 35V all)
2.---loose connections fly back terminals. (resolder)
Rca d52w20 52 IN
Bad capacitors on Power/deflection board cp150,cp114,cp120 capacitor cp 150 2200uf 16v, cp114&cp120 220uf 35v
52 in rca tv
does the light blink 3 times when you press power? Let me know exactly what happens when you press the power button. Please respond to this same post when replying.
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
