Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
No sound or add and remove programme - Creative Labs Sound Blaster Live! 5.1 Sound Card
    Problem Solver:
  • 7 Answers
Go to Start, Program, Accessories, System Tools, and select System Restore. Choose a date you know when you had sound and your Add/Remove Programs showed up in the Control Panel. If restoring your computer to a earlier date the first time try several dates. Finally if none of the dates work, than you will probable have to reformat your computer.
Posted on Jan 19, 2008
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
Can not hear anything , but driver sound it done
remove the sound driver from Add / Remove programme
then ones again try to install the driver.
If problem persist then desable the device from onboard.
Put another PCI sound card and run.
Apr 30, 2011 | Computers & Internet
I changed my window from window vista business to window xp , now i have window xp. but after installed it i lost the sound of my laptop compaq presario c700. i lost audio and sound device,...
you just go to control panel add/remove programm then
Click the "Add/Remove Windows Components" button on the left side of the window to display a list of available components.
Highlight any available component you want to install like sound. If the "Details" button is displayed, click to view sub-components. Check the box next to the "Sub-Components" or "Components to Add" options.
Click the "Next" button to complete the configuration wizard and the "Finish" button to close the Windows Components Wizard
Oct 22, 2010 | Computers & Internet
I want to delete my gateway anti theft device from my gateway computer. I have vista 64 bit.
Click on Start - Control Panel - Add/Remove programmes.
When its loaded double click on the requisite programme, select add/remove. It should uninstall the soft ware.
Jul 09, 2010 | Computers & Internet
How do I replace/sound driver for a Medion Akoya EX?
go through start-control pannel-add/remove programme-sound driver-ok
Sep 07, 2009 | Medion (40010998)
I have no sound on GEForce 7050M-MV2.0 I run
Need to cross check some points:
-> check if Realtek already installed in Add/remove Programmes ( can be some CMI entry and Broadcom entry)
If yes->
Start Windows in safe mode.
-> Ignore (cancel) all “found new hardware” prompts
-> Uninstall Realtek(CMI) and Broadcom applications from Add/Remove Programmes
Reboot into normal mode… ignore all found new hardware prompts again
run the driver CD again for both.
I Hope it will work.
Jul 30, 2009 | Computers & Internet
Somebody while working in my p.c has removed the sound system in the year 2006 april.
First of all u go to start- programme- accessories-system tools then click on system restore , system restore in back date when ur computer sound was working fine . After that if ur sound is not coming then go to controll pannel then add/remove programme , remove the sound driver and then restart the pc , after restarting the pc then reinstall the sound driver properly then after install the driver check
Jun 01, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Unable to remove programme
Try to unstall using the add/remove program.
Here's the step
1. Click start
2. Click control panel
3. Click add/remove program
4. Choose the program you want to remove then click remove.
Hope that will solve your problem
Dec 01, 2008 | Philips J44414
Programme removal
click start > control panel > add or remove programmes
Then select the programmme u want 2 remove from "the add or remove panel list" and click remove.
May 11, 2008 | Microsoft Windows Vista Ultimate Edition
Uninstall problem
Restart your system and press F8 .Run window in safe mode .Then do this by add remove option
Mar 02, 2008 | LG Studioworks 45 14" CRT Monitor
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
61 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
