Question about Quantum SuperLoader 3 LTO-3 Tape Drive
Getting error message "Bad element"
Received and error "Bad Element" and we cannot eject the tapes. How do you manullay rremove them?
  • KennyL Jan 18, 2008
    Is there some sort of special screw driver to open the case? All of the screws look like a phillips or cross point but routed out. These are what came from the factory. Other then that I don't see how to open the bottom of the system.
  • 3 Answers
What usually happens is that the device gets out of calibration with the picker and a tape gets stuck in the drive. To solve this, remove all tapes from the magazine(s) and put the magaize(s) back in. Next power down the unit and remove the power cord for about 15 secs to disrupt power. Plug back in and power up. When it comes up it will go through a calibration. When it is Idle, if the tape is still in the drive, you can use the move command to move it to a slot. Unfortunately, if this is a reoccurring problem with multiple 2B errors and then a communication error with the device going offline and no longer available in device manager, the chassis will need replaced. I have had to replace everyone that my clients have had, some more than once, due to this. This and their horrid customer support is why we no longer sell Quantum.
Posted on Mar 22, 2010
    President:
  • 4,402 Answers
You have to open the bottom and turn the motor or gears , just be sure to turn the cartridge gears too to wind the tape back in
Posted on Jan 18, 2008
  • Cary Farah
    Cary Farah Jan 18, 2008
    it's a torq 10 or 15 i think
Why do I get the error code C:32:11 or C:31:42?
Does it try to eject the tape? Try a gentle help on that. The tape may have gotten snarled in the camera.
Sep 03, 2014 | Sony Handycam DCR-TRV280 Digital Camcorder
My jvc camcorder shows me a message that my unit is on safeguard mode
E04 is the only one that a consumer can try to rid. This error normally is the fault of a bad tape. I recommend removing battery and HOLD DOWN EJECT, while reconnecting battery so its the first command camera sees. if tapes eject, try a new tape.
Jul 22, 2014 | JVC Video Cameras
ERROR FF20 AND FF5
Hello Heather, this is JK. I understand that you received two error messages, F20 and F5. Typically, the F20 error indicates a communication failure between EOC and ESEC system and the F5 indicates that there is a runaway temperature. Based on the fact that you received both error messages, you may need to replace the EOC (Electronic Oven Control). Hope this helps!
Apr 19, 2014 | Frigidaire Kitchen Ranges
Keep getting 0E4 CODE ????? ON JVC MINI DV
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Sep 08, 2009 | JVC GR-DVL520 Mini DV Camcorder
Eo4 eject and reinjert tape, unit in safeguard mode .it´s a jvc mini dv model no. gr-d225e digital video camera. I can see thought the camera come on okay.
CPU.
Sep 08, 2009 | Video Cameras
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Not ejecting
DRUM FG
set off.
CPU.
Dec 23, 2007 | JVC GR-AXM17U Camcorder
E04 Safeguard mode due to Dirt head
CPU.
Nov 06, 2007 | JVC 580136 Camcorder
An error message.
CPU.
Nov 01, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Quantum SuperLoader 3 LTO-3 Tape Drive Logo
1,163 people viewed this question
Top Quantum Computers & Internet Experts
SirEbrum
terminalcon
Tony
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
