Question about Canon PC-950 Black and White Copier
How do I change a Laser Unit in my Sharp AR-162 copier?
I have the part and just need to get instructions how to open up the machine and change the laser unit. I've been searching to try to find free downloads of the manual but everyone wants to charge. Can anyone help?
  • easybreeze Jan 18, 2008
    Model is Sharp AR-162 Digital Copier
  • 77 Answers
Laser unit locates under the recieving tray.
open the bottom cover at the delivery section.there you find the laser unit.
Posted on Feb 09, 2009
    Problem Solver:
  • 5 Answers
First what model of canon printer is it..we are talking about..
Posted on Jan 18, 2008
6ya staff
SOURCE:
MODEL: SHARP AR-M160 appears L6 and when i am pressing SATART BUTTOM appears number 10
you need a service technician to check the machine maybe the laser unit of your machine is not functioning
Mar 27, 2011 | Sharp AR-160 Copier
Error Code E7-11 on a Sharp AR-287 photocopier
This code is related to laser unit functioning problem. Power the machine off and on and if it appears again, do the following;
  1. Open document glass and clean inside mirrors and document glass with a clean dry soft cloth and test.
  2. Check flat cable that connects copy lamp and attach firmly from the main board.
  3. Replace the laser unit if the above fails.
Ask for assistance if you doubt from a qualified technician and you will succeed.
Dec 20, 2010 | Sharp AR-M205 Copier
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
Aug 12, 2010 | Sharp AR-M162 All-In-One Laser Printer
IS IT SAFE THE RADIATION OF SHARP AR-M35OU+
I am assuming you mean laser radiation from the laser unit that the copier uses to write the images on the drum. if correct, normally when front door cover is open the laser unit is disabled and no laser radiation is present and therefore it is safe.
Dec 18, 2009 | Sharp AR-M350U Copier
SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Sep 01, 2009 | Sharp AL 1631 Copier
Sharp ar 5320 foud code F 7
Hello sir;E7 that' means this machine laser unit have problem, remove it send it to shop for repair.
May 14, 2009 | Sharp AR-5320 Black and White Copier
Sharp Ar 160 showing error E6
You need put off scanner unit, then put off laser unit to clean mirrors and mirrors in motor. You are tech.?
Jan 19, 2009 | Sharp AR-160 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-162 Laser Unit
searching for solve problem L6 error in the machine sharp m 160
Jan 19, 2008 | Office Equipment & Supplies
Open Questions:
See all Canon PC-950 Black and White Copier Questions
Canon PC-950 Black and White Copier Logo
46 people viewed this question
Clive
Clive
old marine
old marine
Ekse
