Question about Motorola Mobility V220
Answering Delay. Hi. When I receive a call and I answer, there is a long delay before I can hear the callers voice. If I use the speaker phone I can hear the caller immediately. Can you help. Bram
  • 73 Answers
Get a TORX 6 screwdriver
WIggle the tiny flex cable connector
near the hinge.. still no luck ????
Buy another V220 on ebay
gently take the phone apart and sub in the whole
screen shell and front of keypad.
DO NOT TRY TO remove the screen from the body section..
you will destroy to the teeny tiny flex cable.
Google for V220 take apart/ disassembly
Posted on Feb 24, 2008
6ya staff
SOURCE:
Incoming call is delayed from ringing 7-15 seconds
First you will have to explain what transmission network is being used, maybe the delay could be on that. What cards are you using to provides the voice circuits?
Regards
Len
Oct 24, 2012 | Alcatel Newbridge MainStreet 3624...
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
When the phone rings and the person answering the call can hear the caller the problem is: the caller cannot hear the voice of the person that answered the phone.
you can try to use a headset and see if it will work
normally if the caller cannot hear the receiver theres some problem with the mouthpiece. if the headset and loudspeaker works then you have to go to the store and have it fixed.
hope this help
Sep 08, 2010 | Cell Phones
I have a cordless phone/answering machine,40-channel 900 MHz, #26998. Recently, I am not aware of message until 3-4 days after caller leaves message. what is causing delay?
Make sure your phone service provider is compatible with your home phone. If you contact them they can usually provide you with a list of incompatible phones. Next call your home # see how many rings before your answering machine picks up. Check to make sure message is clear and audible. :Leave yourself a message. Note the time it takes for your message to become retrievable. If there is a signicant delay there might be a equipment malfunction and you should contact phone manufacturer.
Oct 13, 2008 | GE Lands Phones
Set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
Oct 01, 2008 | Siemens Gigaset S455 Cordless Phone
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
Sep 23, 2008 | Siemens Gigaset S455 Cordless Phone
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Motorola Mobility V220 Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
