Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer/scanner will not turn on,I think it's in the power adapter
Our printer(all in one) will not turn on, I've uninstalled it andreinstalled it and still there's nothing We bought two of these in March of 2007, this one has not worked since october of 2007 The warrenty is still o. I would like another one (we have receipt) It was bought atOffice max in Danville, VA please let me know something soon. Thanks Joyce Lowery
  • 1 more comment
  • rohos Jan 19, 2008
    I do not want to pay for an Assistance plan, Let me know what I need to do I think the problem is in the power supply box.
    Thanks Joyce Lowery
  • ktlea87 Jan 20, 2008
    I changed the printer ink a few days ago and once I did that every time I turned on my printer it printed an alignment page. So I decided that I just wouldn't turn it off. Well yesterday it just wouldn't turn on. I've tried everything...it seems like a lot of people are having issues with this printer..I am an online student so I guess I'll just have to buy a new printer :/
  • Anonymous May 29, 2008
    MY 3180 WILL NOT TURN ON, IT SEEMS LIKE THERE'S NO POWER WHAT DO I DO?
Posted on Jan 20, 2008
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
I have two laptops both have XP I have this SCSI scanner that I want to use with them. I got to work on the older laptop but on the newer one the SCSI adapter is not being recognized. I've installed...
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
May 27, 2011 | Adaptec SlimSCSI 1460 (apa-1460d)
My printer will not turn on it worked yesterday and i've done nothing different. could it be the "brick"?
Try to unplug the power adapter from the printer.
Check if it's warm or cold. It could be a defective power adapter issue. Unplug and replug the power cord into the power outlet to reset it. Bypass any surge devices or power strips. Replug the power adapter into the printer. The printer should automatically turn on, otherwise press Power button.
If problem continues, then it could be a faulty power adapter problem. I'd suggest you to contact Lexmark technical support for additional assistance.
May 17, 2011 | Lexmark X2500 All-In-One Printer
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
My toshiba nb205 turns on but doesn't display any thing on the screen
I've had this problem before and all I do is to power drain. Follow these steps.
  1. Turn computer off.
  2. take the battery and ac adapter out.
  3. Press and hold the power button down without any power supply for about 30 seconds.
  4. Put the battery and ac adapter back in.
  5. Turn the computer back on.
You should get your display back. Thank you for visiting FixYa!
May 04, 2011 | Computers & Internet
I can't activate my scanner. and i've already lost mu manual for it.
well i can't and i&#;ve im not sure i fully understand
Apr 18, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My daughter has acquired a Mustek 600 III EP Plus scanner, unfortunately without a power supply. I know it is 15 volts 1 amp dc, but is it +ve or -ve tip?
Mustek 600 III EP Plus scanner, Power adapter type output +15VDC/1A Positive Polarity (positive inside and negative outside).
Sep 25, 2009 | Mustek TwainScan 600 III EP Plus Flatbed...
Disable scanner or uninstall scanner function
Did you tried selecting xerox documate scanner as a default scanner, i think before you uninstall hp 7310 you should try that
Aug 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanner issues
disconnect the printer from the computer and also unplug the power adapter of the printer , wait for 30 seconds and reconnect the power adapter and try to copy a document , if it works then there are no issues with the scanner.
if it still gives you the msg scanner busy. then click on start ----->click on RUN-----> type "control printers" click OK , right click on dell AIO 924 and then click "cancel all documents".
restart the printer and then try scanning.
May 16, 2008 | Dell 924 All-in-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
