Question about Marvin 2060 Compact Heater
Intermittent heater control Marvin 2060
Marvin 2060heat control intermittent. Sometimes heater stays off, sometimes stays on all the time. Any way to fix? Warranty support phone number? The one on unit 800 733-1706 says DISCONNECTED.
On Monday, 1/21/08, I returned the Marvin 2060 heater to the store I purchased in 02/07 since the freeze guard stop working. The owner left me a voice message at home and said he after doing some research, he discovered Marvin went out of business in 12/07.
And the heater is no longer covered under the warranty. The owner gave me a telephone number, 800.326.3690 which carry the parts for Marvin Heater. I have not called the number since I am looking for another heater with the freeze guard feature since it something I need quickly.
Posted on Jan 24, 2008
    Problem Solver:
  • 18 Answers
I would first need to know more about the situation to be sure but here are the most likely.
If with themostat turned down and room temp is above where unit should run then the thermostat switch contacts are not opening making continue to heat the other problem, the no heat is due to same switch not closing or the contacts of the tip- over not closing.
If we can be of help fill free to contact D & M Services 912-293-7883
Posted on Feb 28, 2009
Kenmore 106 56666500 not staying cold intermittantly?Does this sound like a defrost thermostat problem?
Look into the freezer and at the rear wall does it have frost building like the photo HERE If yes you will need to manually defrost the freezer with a hair drier or by placing a bucket of hot water inside the freezer and closing the door. Remove the rear wall of your freezer and see if the defrost heater and the defrost thermostat are good. This is the defrost heater part number=> 2323198 Defrost Heater Assembly The defrost thermostat part number is 2319914 Defrost Thermostat If both test OK the next part is found inside the fresh food compartment and behind the control panel=> 2313172 Main Control Board I am here to answer any questions you have, Thanks Sea Breeze
May 22, 2013 | Refrigerators
Cruise control stops working when heater/defroster fan quits working
one possibility either the cruise control is on the same circuit line with the heater/defroster fan and same fuse. try to solve the problem with the fan and you will notice the difference.
Sep 17, 2012 | 2000 Chevrolet Impala
My heater periodically works in my 99 ingrigue. Super frusturating. When i start it sometimes it works and sometimes it doesnt.
The temperature display and the heater function are likely two different issues. I had a similar issue with intermittent heat on my 2001 Aurora. In my case it turned out to be the blower motor. As a vehicle ages and the bearings on the motor start going bad, the amount of energy it takes to spin the motor gets higher and higher. This can result in intermittent behavior or cause the heater resistors to go bad. It is also possible that the heater control itself is the issue, but with the age of this vehicle, I would start with the blower motor and then heater resistors.
Dec 28, 2011 | 1999 Oldsmobile Intrigue
Just replaced the igniter in my maytag gas oven. Before I replaced it all was fine but since the replacement igniter was installed oven stays on all the time. I have to unplug power so igniter will turn...
Your oven switch or control has failed. This is the only way power can get to the igniter. Sometimes this is the cause for the igniter failure like the previous one you had. Could have fried it out pretty quick.
Apr 09, 2010 | Ovens
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
A/c blow hot air 03 jag s type R
You have 2 zone temperature control control. The heater control valve has failed and is open allowing the passenger side heater core to stay hot.
It is a very common problem and expensive to repair. It tends to be an intermittent problem and sometimes will work properly.
Jul 12, 2008 | 2000 Jaguar S-Type
Marvin 2060 Compact Heater Logo
232 people viewed this question
Top Marvin Heating & Cooling Experts
Daniel Gasser
Level 1 Expert
Oloyede Monsuru
terry stevens
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
